attn: Clayton or anyone who knows about GC's.
that's what I thought.
for those wondering, custom GC's read the length and spring rate in standard measurements (inches, ft/lbs)
the bundled ones are like this. it's not metric either (already tried).
there's a link to tyson's coil-over FAQ in the RR forum FAQ. the conversion is in there...
RJ - who hasnt slept in 2 days and spent 10 hrs wrenching on cars and is too lazy to look it up for you
much thanks RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
How do I tell what my spring rates are?
Ground Control sells Eibach Race Springs (ERS) which are labelled by 3 different values in the following convention: length.diameter.spring rate. However, ERS will come labelled in either Metric (mm.mm.N/m) or English (inchx100.inchx100.lbs/inch) units. 180.64.61 is the same thing as 700.250.350. The conversion from Metric to English is (/.254, /.254, x5.7) "/" means "divide by", "x" means "multiply by".
EK k kay
Suspension & Brakes
Mar 13, 2006 09:39 AM
SkyeC
13
Jan 17, 2003 07:23 PM
