is steel piping still as durable as aluminum is??
i am gonna buy some steel BOV flanges from this guy and steel and aluminum cant be welded on...so i wanted to know if my intercooler piping was steel would it still be as good as the aluminum 1 (jsut the charge pipe) let me know thanks
It'll just be heavier and hold heat a little more.
Why not just find aluminum flanges? I would rather have aluminum charge piping over steel
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
I just bought a aluminum flange for my charge pipe, but my intercooler piping is still mild coated steel.
Reason why my charge pipe is aluminum is cause I reused my AEM cold air intake as the charge pipe.
No.
Keep in mind that air is moving through the IC pipes at a very high rate of speed, and also that, due to the properties of moving air next to a heated surface, little heat wil be transferred to the gas. Heat soak and charge temperature are not something for you to spend too much time worrying about.
