Will these pistons do good?
Old May 30, 2003 | 02:29 PM
LswithJg's Avatar
Default Will these pistons do good?
Hey guys I have the jg 301 cams in my 99 ls. I dynoed them at a 12 hp gain on stock compression but the tech. says that if I have higher compression then I will gain more from the cams. So I was wondering if the oversized ITR cam will work good on my car and push the right compression? Help me out. Please
Old May 30, 2003 | 02:35 PM
VTEC-DA's Avatar
Default Re: Will these pistons do good? (LswithJg)
I would go with b16 pistons. USDM b16 will yield a 10.8:1 CR and JDM b16 pistons will yield a 11.0:1 CR. Both are fine for daily driving and will yield good power.
Edit: And your title should say, will these pistons work WELL.
Modified by VTEC-DA at 12:01 AM 5/31/2003
Old May 30, 2003 | 08:47 PM
. o 69 o .'s Avatar
Default Re: Will these pistons do good? (VTEC-DA)
So b-series pistons are worthwile in an LS?I was also considering this when i do a rebuild on my spare motor
Old May 30, 2003 | 09:10 PM
theman-dlh's Avatar
Default Re: Will these pistons do good? (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">So b-series pistons are worthwile in an LS?</TD></TR></TABLE>
Yes, more compression is good. b16 pistions work good but if you get ITR pistions you have to shave about 1mm on the sides so it does not hit the connecting rod.
Old May 30, 2003 | 10:08 PM
LswithJg's Avatar
Default Re: Will these pistons do good? (theman-dlh)
So you mean to tell me that the b16 pistons are higher compression than the gsr. I never knew that.
Old May 31, 2003 | 06:48 AM
VTEC-DA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LswithJg &raquo;</TD></TR><TR><TD CLASS="quote">So you mean to tell me that the b16 pistons are higher compression than the gsr. I never knew that.</TD></TR></TABLE>
Yes, b16 pistons will yield a higher compression in an LS motor than GSR pistons will.
Old May 31, 2003 | 09:23 AM
10K2HVN's Avatar
B16a/b jdm and usdm are higher then B18C pistons (itr, jdm, usdm).
Topdawgg
Dec 6, 2005 04:03 PM
KillaB-
Sep 19, 2004 10:34 AM
shomershavis
Aug 28, 2004 01:20 AM
rcurry14
10
Aug 6, 2004 08:36 PM
LudeyKrus
Jul 19, 2004 08:38 AM
