Different B-series Pistons In LS Block to Raise Compression?
Old Jul 17, 2004 | 10:45 AM
LudeyKrus's Avatar
Default Different B-series Pistons In LS Block to Raise Compression?
I know it can be done, but i was havin trouble in the search.
What will the different pistons in an LS (B18A) block put the compression at?
Old Jul 17, 2004 | 11:06 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Different B-series Pistons In LS Block to Raise Compression? (LudeyKrus)
CTR pistons should yield a 12.0+ CR
Old Jul 17, 2004 | 11:36 AM
LudeyKrus's Avatar
How about the GSR/B16 pistons?
I'm lookin for somethin around the high 11's, if possible.
Old Jul 17, 2004 | 12:09 PM
X2BOARD's Avatar
Default Re: (LudeyKrus)
The b16 and gsr pistons will increase compression some... the b16 ones I believe get you over 10:1... but I don't have the combustion chamber size on hand to do the figures....
Old Jul 17, 2004 | 12:11 PM
Sliced Beard's Avatar
Default Re: (X2BOARD)
compression calculator << go to that site and play with different variables
Old Jul 17, 2004 | 12:20 PM
LudeyKrus's Avatar
Default Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">compression calculator &lt;&lt; go to that site and play with different variables </TD></TR></TABLE>
AWESOME ! ! ! Thank you very much!
Old Jul 17, 2004 | 12:24 PM
Old Jul 17, 2004 | 03:51 PM
redlineintegra's Avatar
Just FYI, P30/PR3/P61s do not require any modifications to fit, while the ITRs and CTRs do (shaving small end bore of the LS rod).
I'm using the ITRs, should net me about 10.4-5.
Old Jul 17, 2004 | 04:45 PM
Default Re: (redlineintegra)
yeah the R-pistons require a few thousandths be macined off of eace side of the rod so they will fit and center properly
Old Jul 19, 2004 | 05:33 AM
Banned
Good site!
Old Jul 19, 2004 | 06:30 AM
-faded-'s Avatar
Default Re: (LSVTEC 91 Civic)
the jdm itr pistons, shave your head some, and get you a high comp headgasket. it should put you at lease in the mid 11s for comp
Old Jul 19, 2004 | 08:11 AM
LudeyKrus's Avatar
I think I may use the USDM B16 pistons w/ the center head gasket layer removed on this guy's motor. ~11.1:1 CR!
Old Jul 19, 2004 | 08:31 AM
Default Re: (hybridlsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridlsR &raquo;</TD></TR><TR><TD CLASS="quote">the jdm itr pistons, shave your head some, and get you a high comp headgasket. it should put you at lease in the mid 11s for comp</TD></TR></TABLE>
please go to the link I posted above before you spout at the mouth
Old Jul 19, 2004 | 08:37 AM
X2BOARD's Avatar
please go to the link I posted above before you spout at the mouth</TD></TR></TABLE>
The guy was not that far off, einstein... stop trying to flame people.
Old Jul 19, 2004 | 08:38 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">The guy was not that far off, einstein... stop trying to flame people. </TD></TR></TABLE>
pwnd.
THESENUTZ93
Nov 30, 2014 05:39 PM
tealsvteceg
Feb 14, 2008 06:03 PM
Pony_Fed95
Jan 18, 2006 11:10 AM
Topdawgg
Dec 6, 2005 04:03 PM
turbodsmpower
Dec 17, 2002 02:50 PM
