Anyone with a Helms for a G2 Integra...
Old Jul 15, 2001 | 08:28 PM
Lyonel's Avatar
Default Anyone with a Helms for a G2 Integra...
I'm after the horn wiring diagram for a DA-6 Integra. Can anyone assist me with this?
TIA
Old Jul 16, 2001 | 08:48 AM
jonsteR's Avatar
Default Re: Anyone with a Helms for a G2 Integra... (Lyonel)
I don't have a helms manual but what exactly do you plan to do (if i may ask)?
Old Jul 16, 2001 | 12:04 PM
Lyonel's Avatar
I accidentally ripped out the wiring for the horns when I removed the a/c system
Now my stock horn doesn't work. HELP!
Old Jul 16, 2001 | 02:54 PM
Lyonel's Avatar
Default Re: Anyone with a Helms for a G2 Integra... (Teken)
Good to see you back Teken!
Here's the deal, after being a dumbass and ripping out some wires which I initially thought was for the spot lights.. my horn didn't work. I have found the positive cable that goes to the horn and tested it by hooking it up to the horn. It works, but then I hooked it up again... no sign of a beep. Went thru all my fuses and they were fine. Now I'm stumped , is there an external relay for the horn? I think a horn wiring diagram for a DA-6 is what I need.
BTW - did you know you can adjust the pitch of the stock horn by turning a small screw behind it... i just found out after toying around with it. I guess some benefit came from this dumbass experience.
Old Jul 16, 2001 | 06:57 PM
Lyonel's Avatar
I presume the fuse box you're talking about is located inside the car and not the one under the bonnet. Anyway I'll go home and check it out and let you know how i go... thanks again Tek!
didn't know USDM G2s had cruise control.
Lyonel - who can't pull himself off Honda-Tech at work
Old Jul 16, 2001 | 07:55 PM
Lyonel's Avatar
The screw is behind the horn at the top. I'll take a digicam pic of it tomorrow.
Old Jul 18, 2001 | 02:32 AM
Lyonel's Avatar
Ok here are the pics as promised. If you look closely you can see the words UP, DOWN inscribed next to the screw adjustment
http://www.lyonel.8m.com/post/P0001833.jpg
http://www.lyonel.8m.com/post/P0001834.jpg
http://www.lyonel.8m.com/post/P0001835.jpg
Old Jul 19, 2001 | 10:17 AM
Vracer111's Avatar
Cool information on the horn screw, never noticed that before when I've had the front bumper off... Gotta be like Teken on this one and try it out. Hey, if you set one horn High and the other one low, with a special circuit in between, you could have a cool siren thing going on..... .
On the wiring, Does anyone know if the US/Canada wiring is different than the Japanese Domestics and European/Austrailian models? Just curious because I know even within the First series of G2 integras (90-91) things are not interchangeable between model years- Like engine bay fan brackets and some electric items.
smrz914
Audio / Security / Video
Nov 7, 2004 12:09 PM
Tegra
Aug 12, 2002 12:10 PM
