Anyone got an ls running lows 13's
Old Jul 15, 2001 | 08:11 PM
Integra187's Avatar
Default Anyone got an ls running lows 13's
Anyone got an ls running low 13's. If so what mods do you have?
Old Jul 15, 2001 | 08:25 PM
unKnown's Avatar
Default Re: Anyone got an ls running lows 13's (Integra187)
probably turbo
er i dont have a 13 second ls i'm just assuming whta it takes to get into 13's :D
[Modified by unKnown, 9:25 PM 7/15/2001]
Old Jul 16, 2001 | 07:37 AM
AllMotor_ 2.0L B18C5's Avatar
New User
I gotta LS HB running mid 13's all motor as my daily driven car.....13.5@98mph on slicks.....here are my mods:
95 LS B18B with itr pistons, milled head, '00 civic SI intake manifold, DC 4-1 headers, act 6puck clutch, and a z.speed air box.......the motor is stock not built!.... basically high compression motor, ohh i forgot to mention i was running off the headers.........
[Modified by AllMotor_2.0L B18C5, 10:00 PM 7/16/2001]
Old Jul 16, 2001 | 07:46 AM
GSRacer's Avatar
New User
Default Re: Anyone got an ls running lows 13's (AllMotor_2.0L B18C5)
great setup. i like... i like... i like...
Old Jul 16, 2001 | 12:22 PM
VTEC-LesS's Avatar
Default Re: Anyone got an ls running lows 13's (GSRacer)
umm am i missing something here? surely there must be some secrets...
that's insane! haha.. i think that's tight though. i'll definitely pass turbo up if this is possible....
Old Jul 16, 2001 | 12:55 PM
WOTTEG's Avatar
Stock Injectors? No fuel Pump?
I have to give you props for going all-motor, that earns respect.
Old Jul 16, 2001 | 12:59 PM
New User
I know it's hard too believe but it's true.....stock ls motor with that setup ran a mid 13's all day long no secrets.....stock injectors, no fuel pump....just with mods i have listed....this is only my daily driven car.......
Old Jul 16, 2001 | 01:02 PM
WOTTEG's Avatar
Do you just have two cars?
How does your 2.0 Liter B18C5 do?
I bet it'll get 12.5sec 1/4 mile. . . .
Old Jul 16, 2001 | 01:15 PM
New User
Default Re: Anyone got an ls running lows 13's (WOTTEG)
yea i have two cars......my LS-HatchBack is just to get around, my fully built itr motor hasn't been ranned yet.....it should be ready by next race season, I want everything to be right........the motor is expected make about 230hp+ to the wheels........this is a full race car .......
[Modified by AllMotor_2.0L B18C5, 10:16 PM 7/16/2001]
Old Jul 16, 2001 | 01:45 PM
lsturbo's Avatar
that LS hb does run mid 13s all motor......
if you don't believe it.......
we'll be at battle of the import on 7/29
and you can see it......
BTW....my 95 turbo Integra LS ran a 13.05@107mph .......
full weight......boosten at 7 psi
[Modified by lsturbo, 11:05 PM 7/16/2001]
Old Jul 16, 2001 | 02:24 PM
GZR4DR's Avatar
Default Re: Anyone got an ls running lows 13's (lsturbo)
I believe 13.5. Hell i ran 13.7 in my hatch about 4 years ago. Stock headers, stock bottom end, stock injectors, stock fuel pump and stock FPR. Only mods were intake, exhaust, headwork, and some 390 cams, and cam gears. Plus a chipped ecu. Everything else was stock, and the car was in stock trim, not cut up.
Old Jul 16, 2001 | 02:29 PM
JG Luder's Avatar
Default Re: Anyone got an ls running lows 13's (GZR4DR)
13.50 on a somewhat stripped hatch... yeah, easy. I believe it.
Old Jul 16, 2001 | 02:35 PM
New User
I'll be at Battle of the Imports in bakerfiled 7-29-01........you can see it run there...remember this isn't my race car.......Daily Driven...hehehee
Old Jul 16, 2001 | 02:38 PM
VTEC-LesS's Avatar
wowee. could you give me an approximate price list? i wanna surprise some people.. daily driven is very beautiful..
haha i'll be happy with 14's.. don't wanna strip it down
and super low 13's on 7 psi, full weight? dayum i had no idea..
ooh couple more questions. did you have any clearance problems with the pistons? is it possible to run ctr pistons or is that pushing it? were there any modifications with running the si i/m or the pistons?
[Modified by VTEC-LesS, 2:30 PM 7/16/2001]
Old Jul 16, 2001 | 04:06 PM
LSIntegra94's Avatar
New User
Default Re: Anyone got an ls running lows 13's (VTEC-LesS)
What does the static compression end up being with the ITR pistons, and what cc is the head after the milling?
Old Jul 16, 2001 | 07:03 PM
Integra187's Avatar
lsturbo what other mods do you have along with the turbo?
Old Jul 16, 2001 | 08:49 PM
13secLSVTEC's Avatar
New User
CTR Pistons and a B16 head....other normal bolt on's...
13's all day...evey day...all motor...
Old Jul 21, 2001 | 09:00 AM
lsturbo's Avatar
hey integra187 here's my mod.......
drag gen II/III kit.......
aem fuel rail......
rc 310 injectors......
msd wires, 6a, coil, cap........
apex s-afc..........
everything else is stock......
I just got my car tune.......
so i'm planning to break into mid 12s w/the same setup at battle of the import.....7/29/01
me and B18c5 2.0L will be there.......
oh...now i got junk2 cam gears......and probably strip the car down a little..
plus i got a cf hood now..so maybe it'll save some weight??????lolz...ok.....2lbs....
Old Jul 21, 2001 | 12:17 PM
Integra187's Avatar
im gonna probably get the drag III kit. hopefully ill run low 13's like u. how much boost u runnin.
[Modified by Integra187, 9:17 PM 7/21/2001]
Old Jul 21, 2001 | 04:37 PM
bigTom's Avatar
here's a little formula... stock ls motor, stock integra, fuel system, t4 straight turbo, good manifold, good ic, good wastegate, 3" exhaust...
dont forget... this is a bone stock motor... 12.4 on slicks
vinceg143
Jun 19, 2009 10:24 PM
eg6turbo143
11
Dec 7, 2006 09:22 AM
89 pos
11
Feb 28, 2005 03:36 PM
PTL
Jul 17, 2002 12:17 PM
LSBlackInteg
Nov 26, 2001 07:54 AM
