GSR header on LS motor. what will i need to make it bolt up?
Old May 30, 2003 | 10:04 AM
KevronsEG's Avatar
Default GSR header on LS motor. what will i need to make it bolt up?
shorting the exhaust or make it longer? OR i wish it woudl bolt up. THANKS
Old May 30, 2003 | 10:11 AM
thaiphob's Avatar
Nikon!!!
Default Re: GSR header on LS motor. what will i need to make it bolt up? (CIV616)
i'm pretty sure the bolt pattern on the two wont match up.
Old May 30, 2003 | 11:00 AM
Cramerox's Avatar
my friends b16 header fit on an LS..so there might be a chance it will work. The only problem i see you having is if the header is to long or to short to connect with the existing exhaust line.
Old May 30, 2003 | 11:09 AM
zad5's Avatar
wut year gsr and wont year ls. most likely the gsr header will be too short.
Old May 30, 2003 | 11:17 AM
zad5's Avatar
Default Re: (zad5)
Here i found a pic.
Old May 31, 2003 | 07:13 AM
KevronsEG's Avatar
Default Re: (zad5)
the motor its going on is 94-95 and teh header came from 01 so from teh pic it shoudl work right
Myh4tch
Sep 6, 2010 01:03 PM
little B
May 3, 2007 10:25 AM
jrzy2nR
Jan 29, 2006 05:58 PM
MikeSarr_GSR
Aug 8, 2003 10:53 PM
jdmekcivic2eg
Apr 23, 2002 06:22 AM
