ABS lights on??
Old May 29, 2003 | 08:43 PM
92LudeSI's Avatar
Default ABS lights on??
Today when i started my car everything went normal and then a few feet down the road the ABS light came on? i turned my car off and restarted it and it stays off untill i disengage the clutch then it stays on all the time. what could be the problem a fuse maybe or the whole damn ABS stuff and Can I just leave it and not have ABS? thanks
Old May 29, 2003 | 08:51 PM
caLiH22A's Avatar
Default Re: ABS lights on?? (92LudeSI)
i'm having problems with my ABS light myself. it always comes on when driving constantly at 60mph or greater. it goes away when i restart the car.
Old May 29, 2003 | 10:39 PM
Pdu-Nz's Avatar
Jump the check connector and check the code it has stored. It's the same process for the engine check light.
Old May 29, 2003 | 10:42 PM
Synerain's Avatar
Mine also does the same. The ABS light does not come on whenever I start the car. I have to move forward a few feet before it clicks on. I still to this date don't know what it is. I don't think its throwing a code but I'll check again tomorrow.
Old May 29, 2003 | 11:38 PM
tintin11's Avatar
I have a similar problem , the ABS light is always on , its been on for 1 year now and even my mechanic dose not seem to know what the problem is. They think it can be the abs sensor but so far nothing. Now for the strange part , normaly i have no ABS and i have been driving around with out ABS. This winter we got a **** load of snow here in toronto so i went out driving around type of rally stile and the ABS system kicked in , i felt the pedal kicking back during braking. I had ABS for a few days till it died again ...... Still have no fix
Old May 30, 2003 | 12:14 AM
gulf imports
Guest
Posts: n/a
Default Re: ABS lights on?? (tintin11)
my light is coming on **** abs!
Old May 30, 2003 | 03:38 AM
symba's Avatar
Default Re: ABS lights on?? (Synerain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synerain &raquo;</TD></TR><TR><TD CLASS="quote">Mine also does the same. The ABS light does not come on whenever I start the car. I have to move forward a few feet before it clicks on. I still to this date don't know what it is. I don't think its throwing a code but I'll check again tomorrow.</TD></TR></TABLE>
same here...is it the same connector as the cel or is it the one right next to it? I've got a 96 4th gen SI
Old May 30, 2003 | 04:54 AM
prelude1897's Avatar
Default Re: ABS lights on?? (symba)
My **** did that, and stayed on, so I just took the bulb out...
Old May 30, 2003 | 05:14 AM
rjr162's Avatar
Default Re: ABS lights on?? (prelude1897)
i know in the 5th gen the connector is the same for the CEL, ABS, and SRS systems.
Old May 30, 2003 | 06:19 AM
EH2DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">My **** did that, and stayed on, so I just took the bulb out...</TD></TR></TABLE>
ok..... that's a way to hande it.... a very bad way.....
anyhoo, my car started doing the same. damn, i guess this is common with 4th gen preludes...
same thing, i start the car and move a bit and it comes on. and it stays on. my ABS doesn't work.
speed snesor???
Old May 30, 2003 | 09:16 AM
Prelude_2_NV's Avatar
Default Re: ABS lights on?? (BB1)
My car did that a few weeks ago. I checked the speed sensors and one of the screws on the bracket came loose. I tightened it and it was all good.
Old May 30, 2003 | 08:24 PM
EH2DX's Avatar
Default Re: ABS lights on?? (Prelude_2_NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude_2_NV &raquo;</TD></TR><TR><TD CLASS="quote">My car did that a few weeks ago. I checked the speed sensors and one of the screws on the bracket came loose. I tightened it and it was all good.</TD></TR></TABLE>
i'm gonna check mine soon.... i hope it's the same thing.
Old May 31, 2003 | 12:51 AM
Imprezn's Avatar
i have the same abs lighting problem, how do i get to the speed sensor?
bonstokLS
Mar 30, 2014 10:51 PM
ChesterNL
Aug 1, 2011 11:35 PM
1baddturbosi
Jun 6, 2008 05:23 AM
vain
Apr 13, 2003 12:40 PM
Lost Type R
Mar 22, 2003 07:32 PM
