Tach needle is bouncing around
Old May 29, 2003 | 03:37 PM
jdircksen's Avatar
Default Tach needle is bouncing around
The tach is bouning around,and sometimes doesn't work at all. Car is a 96 EX with LS/Vtec. Any ideas what to check?
Thanks
Old May 29, 2003 | 03:39 PM
RyanAutry's Avatar
Default Re: Tach needle is bouncing around (jdircksen)
Igniter might be going bad.
Old May 29, 2003 | 03:48 PM
scratchline20's Avatar
Yeah, check your ignitor.
Old May 29, 2003 | 03:55 PM
jdircksen's Avatar
Default Re: Tach needle is bouncing around (RyanAutry)
WTF is an ignitor? Where is it located?
Old May 29, 2003 | 04:16 PM
germz's Avatar
was the cluster ever taken out?
if so, some screws might be loose
it happened to my buddy's temp gauge (working & not working)
Old May 29, 2003 | 04:40 PM
The ignitor is inside the distributor. It has four? wires going to it. It's held to the housing with two small screws.
Old May 29, 2003 | 04:50 PM
Touch's Avatar
Default Re: Tach needle is bouncing around (scratchline20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchline20 &raquo;</TD></TR><TR><TD CLASS="quote">The ignitor is inside the distributor. It has four? wires going to it. It's held to the housing with two small screws.</TD></TR></TABLE> new one'll run you bout $100 I think
yup. easiest thing is to take the distributor off, remove the cap and rotor, then unscrew the plate holding it down, remove the wires, then put the new one in and reverse the steps. good luck; just did it to mine so i know.
usafhanda
Mar 14, 2012 10:29 PM
GrenadaK20
23
Aug 19, 2010 07:45 PM
crxcess
May 5, 2005 08:35 AM
DC 2
Mar 9, 2004 08:40 PM
Timmayeg
May 31, 2002 05:03 AM
