advice for Turbo
Old Jul 15, 2001 | 01:47 PM
AccordTVMan's Avatar
New User
Default advice for Turbo
I am lookin to get more power in my car. I am thinking about turbo-ing my 97 accord lx. I want to know if it is a good idea if i only run about 6-10 psi. Please let me know
Old Jul 15, 2001 | 02:11 PM
SOHCArchangel's Avatar
Default Re: advice for Turbo (AccordTVMan)
yeah that sounds right, i would also get an oil cooler and 2.5"-3" from the turbo on back exhaust wise, and have it tuned good
[Modified by SOHCkordVTEC, 3:12 PM 7/15/2001]
Old Jul 15, 2001 | 03:10 PM
New User
Default Re: advice for Turbo (SOHCkordVTEC)
alright cool, i don't want my motor to blow up do you think 10 psi is too much or should i stick with 6?
Old Jul 15, 2001 | 03:31 PM
well, our motors have pretty low compression 8.8:1 is like almost perfect turbo compression, i would just do a copper headgasket and do some good tuning, and possably a cam to liven things up a bit...
Old Jul 15, 2001 | 04:27 PM
New User
Sounds good to me. I much horsepower do you think i will gain with this turbo? Just a ball park estimate...I figured 100 more almost
Old Jul 15, 2001 | 04:37 PM
Rob03Pro5's Avatar
Glad you are going to turbo your '97 LX. My friend has the same car and has been pondering the idea for a while. How much hp will you get from 6psi? Well that all depends on the turbo you get. Different turbos will have different flow characteristics.. expect lower hp levels on a T25, or T3 compared to a T04/T3. You really shoudln't worry too much about "how much psi you can run.." because its really the output of the turbo that puts the stress on the engine.
For example: (numbers are for making a point.. not actual dyno'd numbers)
Lets say you make 190 hp to the wheels on a T3-Super 60 at 6psi.
If you were to swap out the turbo and put in a T04/T3, you can expect 220 hp to the wheels at 6psi. This is because the T04/T3 puts out more cfm than the T3-Super 60.
Find out exactly which turbo you want to get.. then you can figure out what max hp you can make at a safe boost level.
Btw, do you have an auto tranny? My friend does but he's wondering if the added power of a turbo will tear up the tranny.?
Old Jul 15, 2001 | 07:08 PM
Default Re: advice for Turbo (Rob92SC)
yeah its all bout airflow,
Old Jul 15, 2001 | 11:45 PM
Bootie Monger's Avatar
New User
turbos and autos don't mix well i'm afraid. my friend has a ls integra, it was a turbo auto at about 8 psi (his engine is built), after about 6 months of driving, some hard some normal, he couldn't use reverse. he then swichted to manual. i'm not sure but i think he had a torque converter, i know he had an lsd. supposedly Level10 can make a prelude tranny handle the power fr a jackson racing supercharger so i don't see why they wouldn't be able to work on our tranny's.
Old Jul 16, 2001 | 05:02 AM
Default Re: advice for Turbo (Bootie Monger)
auto is only good for low rpm torque monsters like v8's and other special cases, if it is an auto, id toss it out the window
Old Jul 16, 2001 | 06:07 AM
gns30's Avatar
New User
I know he is looking to put a turbo on his 97, but has anyone seen a turbo manifold for a 98 or newer? I have searched high and low and can't find one anywhere!
Old Jul 16, 2001 | 07:09 AM
Default Re: advice for Turbo (gns30)
it should be the same head pattern.....and it really shouldnt matter
Jxi8s2k
Honda S2000
23
Dec 12, 2005 05:53 AM
aLL_MoToR_EH2
Feb 20, 2003 04:32 PM
Hondasaurs
Nov 5, 2001 07:38 PM
itr501
Jul 20, 2001 01:39 PM
