Can i run 440 injectors on my stock fuel pump?
Old May 28, 2003 | 04:09 PM
psileepR's Avatar
New User
Default Can i run 440 injectors on my stock fuel pump?
Car is a d16y8 99 civic coupe :
gonna run the sohc greddy kit w/afc hack
planning on running stock boost 5.5psi till i get it tuned with the hack.
at this low psi would i need to install a high flow fuel pump?
Old May 28, 2003 | 04:16 PM
1bar's Avatar
Default Re: Can i run 440 injectors on my stock fuel pump? (Civtek)
no you should be fine
Old May 29, 2003 | 09:05 AM
psileepR's Avatar
New User
Default Re: Can i run 440 injectors on my stock fuel pump? (1bar)
thanks .. second opinion? anyone
Old May 29, 2003 | 10:15 AM
b18b98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bar &raquo;</TD></TR><TR><TD CLASS="quote">no you should be fine</TD></TR></TABLE>
I 2nd that.
Old May 29, 2003 | 02:11 PM
EVIL_AWD's Avatar
Default Re: Can i run 440 injectors on my stock fuel pump? (b18b98)
I triple that, you will be fine.
Old May 29, 2003 | 03:09 PM
ScottEK's Avatar
Default Re: Can i run 440 injectors on my stock fuel pump? (ITR420)
I've had a similar question, here's my scenario...
B16A with a .60 T3 running 7PSI w/ DSM 450cc and AFC Hack, should I be concerned with upgrading to a bigger in tank fuel pump?
Old May 29, 2003 | 03:11 PM
E-Rok's Avatar
EPIC TUNING
Default Re: Can i run 440 injectors on my stock fuel pump? (beta13)
you can use the stock one, but I reccomend upgrading
Old May 29, 2003 | 11:24 PM
psileepR's Avatar
New User
Default Re: Can i run 440 injectors on my stock fuel pump? (rewsnaeht)
thanks everyone
pa2play
Feb 28, 2005 09:39 AM
honda9369
Oct 11, 2004 02:56 PM
yusoslo
Mar 23, 2004 01:54 PM
rjardy
Oct 14, 2002 08:15 AM
BorderM3
Sep 5, 2002 11:58 AM
