Fuel Pressure and Timing
Can someone please help me. My car is backfiring and cant keep up with cleaning my bumper from all the black stuff coming from my exhaust.
Heres my setup. i would like input on what my fuel pressure should be and my timing.
currently set to 40psi vaccum in and timing is 16deg and vafc is +2 all accross.
car is backfiring but plugs are still on the white side.. so i dont know whats happeneing.
b18c1
pr3 piston
Port/Polish
Skunk2 Im
Dc 4-1 Headers
ITR camshafts
AEM Cam Gears
B&M Fuel reg
JDM h22a Injectors
VAFC
2.5 custom exhaust
with the pistons and the head shave compression is at 11.7:1
this is in a 90gs with a pr3 ecu /mugen chip to disable 2nd o2sensor
All help is greatly appreciated.
__________________
GsTeg90
erassi@hotmail.com
Modified by GsTeg90 at 9:23 PM 5/28/2003
b18c1
pr3 piston
Port/Polish
Skunk2 Im
Dc 4-1 Headers
ITR camshafts
AEM Cam Gears
B&M Fuel reg
JDM h22a Injectors
VAFC
2.5 custom exhaust
__________________
GsTeg90
erassi@hotmail.com
this might help....bump your fuel psi to 46 psi with vacumm on. if you have cam gears advance them +2 degrees on the intake and +1 degree on the the exhaust side. set your ignition timing to 18 degrees. i can almost guarantee you that your car will run much better. let me know the results. peace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatchrips »</TD></TR><TR><TD CLASS="quote">this might help....bump your fuel psi to 46 psi with vacumm on. if you have cam gears advance them +2 degrees on the intake and +1 degree on the the exhaust side. set your ignition timing to 18 degrees. i can almost guarantee you that your car will run much better. let me know the results. peace</TD></TR></TABLE>
just wondering how did you come up with the +2 deg on the intake and +1 deg on the ex how will that affect the engines preformance
