tranny fluid
Old Jul 14, 2001 | 11:57 AM
CardDealer's Avatar
Banned
Default tranny fluid
Modified by CardDealer at 4:13 AM 11/16/2006
Old Jul 14, 2001 | 01:18 PM
976's Avatar
976
New User
Default Re: tranny fluid (schlit)
Well since you don't drive it hard, you should change to synthetic, but not redline, it's designed to fast ranning transmissions. Well, 5-sp trannies.
Anyway, find a decent synthetic ATF and change if you want, but if it is clean, then there is no need.
Old Jul 14, 2001 | 03:13 PM
fixhondas's Avatar
Use Honda ATF- it is more durable now . However- honda autos need their fluid changed at least every 30k. If it was mine I'd do it every 15K. The amount of silver gunk you found on the drain plug is clutch pack material. I have yet to see any other fluid provide as smooth of a shift as Honda fluid.
Old Jul 14, 2001 | 05:04 PM
CardDealer's Avatar
Banned
Default Re: tranny fluid (fixhondas)
Modified by CardDealer at 4:14 AM 11/16/2006
Old Jul 14, 2001 | 05:42 PM
fixhondas's Avatar
Yes it is ok. You shouldn't have a problem.
Old Jul 15, 2001 | 08:29 AM
CardDealer's Avatar
Banned
Old Jul 15, 2001 | 01:38 PM
976's Avatar
976
New User
Default Re: tranny fluid (Teken)
What do you recommend for 5-sp trannies. Does honda make Synthetic tranny fluid?
Old Jul 16, 2001 | 07:01 AM
serious's Avatar
ooooh, i know i'm gonna get beat down for disagreeing with a moderator. i think it's definitely worth the extra couple bucks (come on, it's only a couple more bucks every 15k miles) to get the honda fluids. i know they're manual transmission fluid is formulated differently then just standard oil (which is what's usually used) and i know that it makes a definite difference. i drive a 5th gen prelude, which are notorious for they're weak transmissions, and you can tell the it goes through the gates easier with honda mtf. check the prelude forum, using the honda stuff does make a difference. i don't know about their automatic fluid, but i do know that it's formualted differently then other stuff, and i would definitely use it if i had automatic.
Old Jul 16, 2001 | 01:06 PM
CardDealer's Avatar
Banned
Default Re: tranny fluid (serious)
Old Jul 16, 2001 | 01:09 PM
CardDealer's Avatar
Banned
Old Jul 16, 2001 | 01:17 PM
fixhondas's Avatar
Honda does not manufacture their fluids- rather they provide formulas for companies like Mobile to mix them. Honda manual trans fluid works better than standad 10w30. I have not tried redline or others. I do know that Honda ATF is GOOD stuff and provides the best shift quality. Also- I have seen Honda manual trans fluid make noisy input shaft bearings quiet common on 92-95 civics.
[Modified by fixhondas, 10:24 PM 7/16/2001]
Old Jul 16, 2001 | 01:21 PM
fixhondas's Avatar
I have not seen a Fram Honda oil filter- I have seen Filtech, Toyo Roki, and a non branded Canadian filter. The Toyo Roki's come from Japan and the Filtech's are made here. The Candian model will feel really light and cheap when you hold it (go figure- its from Canada).
[Modified by fixhondas, 10:25 PM 7/16/2001]
Old Jul 16, 2001 | 03:40 PM
DOHC_VTEC786's Avatar
New User
Default Re: tranny fluid (Jay D Em)
The Candian model will feel really light and cheap when hold it (go figure- its from Canada).
****!!! j/k
CRP
Nov 5, 2017 01:06 PM
mysicivic1991
Apr 16, 2007 09:53 AM
globy123
Dec 17, 2006 07:20 PM
Brolli007
Dec 22, 2002 12:09 PM
CW_97_ITR
Jun 17, 2002 10:48 AM
