Idle speed questions
Recently i did alot of regular maintenance to my 94 with 120k on it and now it seems to idle around 500. I think this is the low end of the range (500-1000). It is smooth, but I was curious if it would be better to make it slightly higher, say 750 or so?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aengnr1 »</TD></TR><TR><TD CLASS="quote">so to raise the idle speed do i just have to adjust the throttle body set screw or is there a more detailed way to adjust the idle speed?</TD></TR></TABLE>
Typically, on a warm engine, you would unplug the idle air control valve and adjust the air bypass screw on the throttle body to obtain the base idle speed. The Ecu will set a code that you would have to clear, usually by pulling the backup or hazzard fuse for about ten seconds.
OverBoostDemon
Nov 4, 2009 02:55 AM
mr poo
Sep 5, 2006 12:29 PM
