Resistor box on the Crx....change it to Prelude with H22?
Old May 26, 2003 | 10:52 PM
H22CRX's Avatar
Default Resistor box on the Crx....change it to Prelude with H22?
I just recently had a idle problem with the car. Didn't do it before then gradually got worse. From 800 to 1600. I didn't do any research on this before I did swap, but do I need to change resistor box to a prelude one? 91 crx and OBD 1 95 H22. Thanks for any help.
Old May 27, 2003 | 04:19 AM
h22 ef's Avatar
Default Re: Resistor box on the Crx....change it to Prelude with H22? (H22CRX)
all resistor boxes are the same, check your iac (idle air control) theres like a plastic screw thing inside it that can come loose, that or you have a vacuum leak
Old May 27, 2003 | 05:47 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22CRX &raquo;</TD></TR><TR><TD CLASS="quote">91 crx and OBD 1 95 H22.</TD></TR></TABLE>
Got any pics of the motor installed?
Old May 27, 2003 | 09:14 AM
SilverEk3dr's Avatar
Default Re: Resistor box on the Crx....change it to Prelude with H22? (VTECVillain)
Might try cleaning out the IACV and check for vacuum leaks. I also had a problem with mine idleing too high, and it turned out that a few of the alternator wires were switched backwards.
Mark
Old May 27, 2003 | 11:06 AM
Jeff C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">Got any pics of the motor installed? </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=504813
Old May 27, 2003 | 12:43 PM
H22CRX's Avatar
Default Re: Resistor box on the Crx....change it to Prelude with H22? (Jeff C)
I already did the plastic screw and that didn't fix it. It's not a high idle, it revs. Like 800 to 1600 back down to 800 up to 1600 and so on. I was thinkin that maybe a crx resistor box has a higher resistance then a prelude one would have, but I'm not sure.
Old May 27, 2003 | 01:02 PM
As they said....all the resistor boxes are the same. Your not getting any cel's? IS your TPS adjusted right/ has it been taken off?
Mark
Old May 27, 2003 | 03:44 PM
H22CRX's Avatar
Default Re: Resistor box on the Crx....change it to Prelude with H22? (SlvrEj6Dx)
No check engine lights or anything.
Old May 27, 2003 | 04:10 PM
poison's Avatar
damn that looks good!!
Sounds to me you either have air bubbles in the coolant system, a vacuum leak, the throttle body not adjusted properly, or the fast idle valve under the throttle body is loose.
Inspect those and see what happens.
chihuahuamanx
Feb 17, 2005 11:52 AM
H22CL
Dec 18, 2003 05:36 PM
SAVIOVEGA
Oct 11, 2003 08:27 PM
ManInTheRedCoat
Oct 1, 2003 08:45 PM
thehatchninja
Dec 9, 2002 09:16 AM
