zex on an 88 'lude
Old May 26, 2003 | 08:23 PM
brent1223's Avatar
Default zex on an 88 'lude
Hey, I want to put a 75 shot of zex on my 88 prelude (b20a5), I have an intake and and a muffler, no biggie... I just want to know if this is safe (190,000 miles) and if i should use 87, 89, 91 or 92 octane??
Thanks a Lot!,
-Brent
Old May 26, 2003 | 10:00 PM
PAID-$$$'s Avatar
Default Re: zex on an 88 'lude (brent1223)
uh...................ur car is too old, instead invest in a new car, then get NOS
Old May 27, 2003 | 11:02 AM
red91sit's Avatar
You hsould do a compression check to know for sure, You might want to run colder plugs too and use the highest octane u can get. if u run slicks with it you should break into the 13's
Old May 27, 2003 | 11:26 AM
BA5's Avatar
BA5
so long as the engine is in decent shape it'll hold up just fine. I had the NOS on mine for a while and i had over 180k's on my engine. held up just fine.
Old May 27, 2003 | 06:06 PM
Ima2nr's Avatar
Default Re: zex on an 88 'lude (PAID-$$$)
Re: zex on an 88 'lude (brent1223) (PAID-$$$)
well I guess I better get rid of my 89 lude then.... Its so old that it will probably fall apart as soon as my 600 hp H22 starts to spool-up!!!
Old May 27, 2003 | 06:22 PM
optikal_blitz's Avatar
ugh..that thing is so beastly..
anyway, if you wanna safely run nitrous, rebuild the motor (i'm assuming its FI), and make sure its in top working condition before you over stress it.
Old May 27, 2003 | 08:29 PM
sslude's Avatar
Default Re: (NatakuBlitz)
i seriously recommend a re-build or a new car. it just wont hold up. but if you really want to do it, check compression, timing, tuning and make sure you're getting enough fuel for the size shot you're running. hope everything wokrs out.
Old May 27, 2003 | 11:55 PM
97hb's Avatar
If the motor can take it, you better start worring about the clutch.
integ_lude
Mar 25, 2008 06:26 AM
s2geezykubo
Honda S2000
Aug 9, 2006 04:38 PM
Restored_CRX_SI
15
Dec 29, 2004 08:09 PM
T--Rex
25
Aug 29, 2004 02:21 PM
4thgenlude
May 11, 2004 12:56 PM
