freeplay in gears, whats broken in my tranny?
Old May 26, 2003 | 06:49 PM
TurboBumblBee's Avatar
Default freeplay in gears, whats broken in my tranny?
ok i can shift through gears as normal, but when im in gear i can move around the stick like im in neutral.. what the hell is broken? its a b18c1 stock tranny, stock clutch, stock flywheel.. i know i f-ed something up.. need to know how to fix it or if its worth fixing.. it come out of gear when i pull on it.. really weird..
Old May 26, 2003 | 06:52 PM
tominos's Avatar
Default Re: freeplay in gears, whats broken in my tranny? (Hybrid95CivicEX)
could be your shifter bushing.
Old May 26, 2003 | 07:07 PM
Default Re: freeplay in gears, whats broken in my tranny? (tominos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos &raquo;</TD></TR><TR><TD CLASS="quote">could be your shifter bushing.</TD></TR></TABLE>
it has to be more than that.. its weird.. feels like the car is in neutral when its in gear
Old May 26, 2003 | 07:27 PM
eg crunkmonster's Avatar
Yup....just pick up some new brushing
Old May 26, 2003 | 07:52 PM
COMplex.'s Avatar
well of course it will come out if you pull on it.
i agree its probably a bushing. but who knows what ya did lol
Old May 27, 2003 | 09:22 AM
Default Re: freeplay in gears, whats broken in my tranny? (john.fuggi)
any other idea.. i think its internal..
Old May 27, 2003 | 09:25 AM
B2FiNiTY's Avatar
Just check your bushings.
Nextelbuddy's Avatar
if u jack the car up and look under neath where the shifter drops down look under there and look at your shifter bushing along with the bracket that holds your shifter in place it could be loose too happened to me b4
Old May 27, 2003 | 09:46 AM
tonyxcom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX &raquo;</TD></TR><TR><TD CLASS="quote">any other idea.. i think its internal.. </TD></TR></TABLE>
Ok your tranny is fucked and can't be fixed, you need a new one. Is that what you want to hear?
Just check your bushings like everyone is telling you. It wont cost you a dime to check. Geez!
Old May 27, 2003 | 11:37 AM
blazinb16's Avatar
yea definatly should check the bushings....especially if you have one of thoes shitty short shifts
Old May 27, 2003 | 01:13 PM
Default Re: freeplay in gears, whats broken in my tranny? (blazinb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blazinb16 &raquo;</TD></TR><TR><TD CLASS="quote">yea definatly should check the bushings....especially if you have one of thoes shitty short shifts</TD></TR></TABLE>
ok thanks everyone.. and TonyXcom, no need to so harsh.. i knew it was not the bushings cause ive done a 5 swaps and never had this problem knew they were there.. my problem was that the metal peice used to hold the shifter to the tranny, that needs to be punched out was mangled, so a friend put a bolt in there, there was freeplay and the bolt was not big enough causing it move back and fourth.. a friend a shop fixed it for me all i had to do was order him a new one for his race car cause he gave me his..
Old Feb 22, 2004 | 10:22 PM
1SlowSi's Avatar
Well i hate the same problem.. Every car is differnt. I have a short shifter and new Energy Suspension bushings... still lose in all the gears.. My Boy's Si is very tight in every gear.. doesnt really move. Its internal, cause you can only tighest down the bracket so much before is bends and becomes very hard to shift... just deal with it.. i do. still shifts like a champ though.
tei344
11
Jul 18, 2007 10:36 PM
CXtypeR
Jan 20, 2007 02:03 PM
yed
Honda Civic (2006 - 2015)
15
Nov 23, 2006 06:29 PM
Jesterian
Feb 3, 2006 09:23 PM
TurboBumblBee
May 27, 2003 01:14 PM
