Auto tranny fluid change.. how ?
Old May 26, 2003 | 02:42 PM
. o 69 o .'s Avatar
Default Auto tranny fluid change.. how ?
I checked the fuild on my G/F's civic, and the fluid looked like used motor oil. Time to change it. question is: what do i have to do? is it the same procedure as manual tranny fluid change? i.e drain and refill, or is there something I am missing. I asked at the local pit stop and the guy was telling me $128 bucks because he has to change a filter. Last time i checked, there was no filter on honda D series auto trannies.
Old May 26, 2003 | 02:55 PM
drunknbass's Avatar
no filters... it helps if you have atf in a pump where you can just pump it in.
this is a way to get it real clean but ive never done it without using a pump gun with atf.
pop the drain plug and let the tranny drain out all the way..
then put a funnel in the dipstick tube and have someone start the car and go through gears up and down till you pour about 6-8 quarts through, kill the engine and let it drain. plug it up add 2- 2.2 quarts and your set.
pretty much you gotta pour the atf in the funnel as fast as itll empty.
that way itll get alot cleaner than just draining the pan
Old May 26, 2003 | 03:08 PM
. o 69 o .'s Avatar
Default Re: (drunknbass)
awsome.. thanks a ton
KYLE.ECKERT
Nov 14, 2011 05:28 PM
Nooch
Mar 20, 2011 06:37 AM
jay's racing
14
Mar 29, 2005 02:46 PM
professorman
Jan 12, 2003 06:40 AM
