Question about my turbo's filter
This may be a dumb question, but I just installed my Blitz filter the other day, and was wondering if the filter will suck in all the heat from my turbo and manifold down below? Will this cause any problems? There is one other possibility of where I can place my filter, but, this seemed the most convenient.
that does nothing but suck in hot air...did you tap into the back of your block for that oil feed
hope so...i would look around at "cheap" intakes and try to find a design that will slither through the radiator lines and what not. Good luck man...also get a dumptube on the w/g thats no good on ac lines
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSedan »</TD></TR><TR><TD CLASS="quote">Safer to still use a dump tube, trust me.
[Another newbie quetsion] Where do you guys run yout dump tubes? Just to the bottom of the engine bay?
</TD></TR></TABLE>[Another newbie quetsion] Where do you guys run yout dump tubes? Just to the bottom of the engine bay?
it would be wiser to route the air filter on the other side of the radiator hose.
and as far as a dumptube, just point it away from something important.
dgdarien
Sep 26, 2017 04:50 AM
