help - tranny not commin off
Old May 26, 2003 | 11:48 AM
Heinz57's Avatar
Default help - tranny not commin off
hey guys,
I'm trying to take my tranny of right now to replace the clutch...got everything off and have the tranny supported with a jack and the motor supported by the jack...
the problem...i can't get the tranny separated from the motor!!! never done this before..not sure what to do..any suggestsions how to get em separated?? thanx.
Old May 26, 2003 | 11:50 AM
ApexI EX's Avatar
Default Re: help - tranny not commin off (Heinz57)
first make sure EVERYTHING is off that holds it on the, take a flat head or something flat and start prying thats what i had to do.
Old May 26, 2003 | 11:53 AM
Heinz57's Avatar
Default Re: help - tranny not commin off (ApexI EX)
yea, we're pretty sure all the bolts are off...we made sure three times...we tried the screw driver thing..but there aint to gap between them to use a screw driver....is the only thing to do is to just wiggle the hell out of it?? thanx
Old May 26, 2003 | 11:55 AM
eg_nezay's Avatar
Yup, make sure u have all the bolts off.
Did you take out the starter bolt? thats a lil. hidden.
After, just carefully pry it out.
Old May 26, 2003 | 11:58 AM
Archidictus's Avatar
Unceasing Measure
Default Re: help - tranny not commin off (eg_nezay)
Odds are it's the starter bolt. The transmission will let you know when it's 100% unbolted. Don't ream it with a flathead screwdriver: use a rubber mallet if you feel the need to jostle it. Aluminum doesn't take well to gouging.
Old May 26, 2003 | 12:34 PM
88hondahatch's Avatar
take off the starter, thats what i forgot to do and couldnt figure it out till i went down and looked at it the next day
B!^A@
Nov 21, 2006 07:37 AM
AccordVT
Aug 8, 2006 03:46 AM
Unjockable
20
Nov 10, 2003 02:36 PM
gumbybum
Jan 31, 2003 12:25 AM
type r 01-1063
Jul 14, 2002 08:11 PM
