92-95 hatchback rear disc conversion questions
yes, i used the search, i couldn't find anything i was looking for.
anyways, my friend has a 92 cx and he bought my friends 99-00 Si brake set up.
my question is, what master cylinder and brake booster should he use? i've heard of a 91 4 door civic EX master cylinder / brake booster..but thats kinda tough to find.
will the 99-00 Si master cylinder and brake booster work? or any from a 94+ integra?
and last, what e-brake cables should he use? he has the 99-00 Si brake cables.. just making sure if they'll work or not.
TIA
TIA
https://honda-tech.com/zerothread?id=152884
Hope this helps. And i think that the 99-00 si has ABS, and the CX doesn't, so from what i've heard from Tom (B18C5-EH2) he tells people to use 94-95 Integra RS MC and Booster b/c the RS never had ABS equipped, therefore the 15/16 MC and booster will be a direct bolt up to the CX, with no line bending and flaring.
thanks! i guess i didn't find that thread because i typed in "rear disc conversion".
the 99-00 Si's had an option to come with ABS i believe.. because when we took the 99-00 Si rear disc from the car itself, there was no ABS found.
thanks again.
thanks again.
Hmmm, maybe (I don't know for sure) the Si MC, and booster will work, but for a positive answer, I'd look into that thread i gave you for complete details.
Good luck!
Good luck!
Integralove00
Sep 10, 2006 08:59 PM
crush
Oct 20, 2005 07:20 PM
jimmhatch
Jul 17, 2005 12:06 PM
