2002 Civic Si or RSX-S sway bars on a 2003 Civic coupe?
Old May 26, 2003 | 10:52 AM
00TEG's Avatar
Default 2002 Civic Si or RSX-S sway bars on a 2003 Civic coupe?
I was wondering if the sway bars on the 2002 Civic Si or the 2002 RSX-S will bolt directly up to a 2003 Civic Ex coupe? I know if it will I will have to get new bushings but I was wondering if I would have to get new D brackets or end links. Also, should I have to worry about the subframe? I know it was somewhat an issue with my Integra LS b/c it was not bolting to a flat surface. I took care of this with the Comptech sway bar and tie bar set and have had good experience with it, but I would rather not spend as much money with these sway bars. Thanks for all help.
Old May 26, 2003 | 03:08 PM
SlammedBlueEM2's Avatar
Default Re: 2002 Civic Si or RSX-S sway bars on a 2003 Civic coupe? (00TEG)
Being the owner of an EM2 with an upgraded rear anti sway bar...
You don't need the endlinks, just the bushings. The stock brackets work fine.
You don't need to worry about the subframe unless your rear bar is over 21mm thick. For that, you need a tie bar. Any tie bar will do. The subframe in the EM2 Civic is exactly the same as the EP3 Si and RSX.
It's pretty much as simple as that.
Old May 26, 2003 | 06:01 PM
00TEG's Avatar
Default Re: 2002 Civic Si or RSX-S sway bars on a 2003 Civic coupe? (SlammedBlueEM2)
Thanks for the help.
Old May 27, 2003 | 12:24 AM
mateo's Avatar
want the type s bar, i have two w/ bushings, they came off mine and my buddies car!
let me know, i'm in the seattle area.
...m
Old May 27, 2003 | 01:28 PM
00TEG's Avatar
After reading the replies I still don't know that anyone has answered if the Si or RSX-S bars will work. I'm assuming since the sub-frames are the same they will work. Is this correct?
Old May 27, 2003 | 02:10 PM
mateo's Avatar
they will fit!
ok!
but you will need the bushings!
read the posts,very slowly, and i believe you will read that as well!
good luck!
...m.
Old May 27, 2003 | 06:21 PM
www.HondaWerx.com's Avatar
Default Re: 2002 Civic Si or RSX-S sway bars on a 2003 Civic coupe? (mateo)
you wont want a si barm, its smaller than your stock 03 civic EX one. type S=19mm type R=22mm.
Old May 28, 2003 | 02:04 AM
Default Re: 2002 Civic Si or RSX-S sway bars on a 2003 Civic coupe? (www.HondaWerx.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.HondaWerx.com &raquo;</TD></TR><TR><TD CLASS="quote">you wont want a si barm, its smaller than your stock 03 civic EX one. type S=19mm type R=22mm.</TD></TR></TABLE>
That's not true.
The EX bar is 12mm... which does nothing to tell the truth.
The Si bar is 15mm.
The RSX bar is 19mm and is not a Type S only bar. It's 19mm on both base and Type S.
You got it right for the Type R.
theguy22
Suspension & Brakes
13
Aug 19, 2018 08:02 PM
dj12oclock
Honda Civic (2006 - 2015)
Mar 19, 2008 12:19 AM
SoullessJapaneseMachine
Suspension & Brakes
Oct 10, 2007 07:43 PM
00TEG
May 26, 2003 10:43 AM
gakkuken
21
May 23, 2003 02:29 PM
