what ecu program are you using for high compression na?
on my 12.5:1 b20 vtec im still running stock p72 program, i need more rpm but i dont want the crazy advanced timing on the high comp engine, also i would like to keep my knock sensor.
car ran a 13.6 at 106 on street tires friday when i can keep it off the rev limiter so it aint all that bad now, just need some more rpm.
can you suggest a program for stock ecu without switching up to an aem box or hondata.
i guess i could pull some timing off with an e-manage, but raised rev limit and knock sensor together would be ideal for now.
http://Ericksracing.com he can make a custom program for your set up
give Eric a call 310 320-5788
gocivicgo
May 28, 2003 05:30 PM
LsVtechybridracer
Mar 31, 2002 08:44 PM
KJ
Oct 17, 2001 09:07 AM
