Will DOHC ZC head work on my D16A6 block?
Old May 26, 2003 | 09:11 AM
Project91REXSi's Avatar
Default Will DOHC ZC head work on my D16A6 block?
I have a 91 Si w/d16a6 and a friend has a dohc ZC engine with a blown bottom end. He is willing to sell me the head which is in good condition for very cheap but I'm not sure if it will bolt onto my stock block. Any help would be greatly appreciated!!!!! Thanks...
Old May 26, 2003 | 09:18 AM
aLLjDMRalf's Avatar
Default Re: Will DOHC ZC head work on my D16A6 block? (Project91REXSi)
ive allways wondered the same thing just never asked has any one ever done this, it should work IMO
Old May 26, 2003 | 09:22 AM
Vinceg99's Avatar
Default Re: Will DOHC ZC head work on my D16A6 block? (SlOwCrXbUtUbNbEaT)
So you want to put the DOHC ZC head onto your SOHC A6 bottom end?? If thats what your talking about nope it wont fit.
Old May 26, 2003 | 09:25 AM
I don't think there is anything different between d16 blocks and zc blocks but I'd hate to put it together and not notice a missing oil passage or something like that. Plus I'm wondering how much HP gain I will actually realize for the trouble...the stock engine still runs good with 148k!
Old May 26, 2003 | 09:27 AM
Default Re: Will DOHC ZC head work on my D16A6 block? (Vinceg99)
Yep, that was what I wanted to do...why doesn't it work? I guess now that I think about it, if it worked people wouldn't do full ZC powertrain swaps...duh
Old May 26, 2003 | 09:31 AM
What about if I rebuild the ZC engine and put the whole engine in my car, will it bolt in and bolt up to the stock Si tranny? Or would I need the whole ZC engine/trans swap...also, how much HP does a stock dohc ZC put out?
Old May 26, 2003 | 09:35 AM
Malgerus's Avatar
Yes, a DOHC Zc will bolt to your Si transmission... they are both D-series engines. A stock ZC puts out 130 hp.
Old May 26, 2003 | 09:40 AM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project91REXSi &raquo;</TD></TR><TR><TD CLASS="quote">What about if I rebuild the ZC engine and put the whole engine in my car, will it bolt in and bolt up to the stock Si tranny? Or would I need the whole ZC engine/trans swap...also, how much HP does a stock dohc ZC put out? </TD></TR></TABLE>
Yes it will bolt right into your car no mods to have it fit or anything. You can use everything from your Si and bolt just the ZC block into your Si. You can use the Si tranny, mounts, ecu, wiring, everything. The only thing that is different is that the cylinder postion sensor is by the cam and not in the distributor like the Si so you would have to extend those wires to that sensor. I am not sure of the colors of the wires or anything but if you do a search I am sure you will find it unless someone else answers the question in this post. As for how much power I believe that the ZC's are like 130 HP to the flywheel but those numbers can be different depending on age and wear.
*EDIT* Damn I type slow
Default Re: Will DOHC ZC head work on my D16A6 block? (Mr. S)
Are there any mounts or other things I will need to modify to make the ZC engine bolt in? I don't want to attempt this until I know what I'm getting myself into...it would be cool to have a ZC engine under my ZC-style carbon fiber hood!
Old May 26, 2003 | 09:44 AM
Malgerus's Avatar
It's a bolt in. You may have to shim to engine mount so it doesn't hit your hood. The only mod you'll have to do to an Si is extend a few wires.
<U>Do a SEARCH </U>
Old May 26, 2003 | 10:41 AM
drjondurst's Avatar
I know everyone says the ZC head on sohc d-series block wont work but I know two very knowledgable people that say it CAN and HAS been done. Im always like "well.. everyone on H-T says its 100% impossible" and they say "yea well those people only say that because its all they've heard from other ppl b4 them.. has any of them actually tried and failed? no"
So have any of you guys that say you cant do this actually tried it? I mean ona these guys has been messing with hondas for 11yrs and has taught me alot of stuff.. so its hard to ignore what he says.
Old May 26, 2003 | 11:09 AM
Lamchop0000's Avatar
yeh is anybody have a %100 sure answer?
Old May 26, 2003 | 01:57 PM
drjondurst's Avatar
Default Re: (lamchop0000)
All I wanna know is if there is ANYONE here thats physically actually tried pairing the DOHC ZC head with a sohc d-series block.
Old May 26, 2003 | 03:35 PM
boosted_zc's Avatar
Default Re: (drjondurst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjondurst &raquo;</TD></TR><TR><TD CLASS="quote">All I wanna know is if there is ANYONE here thats physically actually tried pairing the DOHC ZC head with a sohc d-series block.</TD></TR></TABLE>
I have and no it does not work, there is one head bolt hole that doesn't line up between the head and block. Not worth the time and money to have a shop fill the hole and retap it.
Old May 26, 2003 | 04:21 PM
drjondurst's Avatar
U serious? what block were you trying to bolt the head onto? I'll see what head these guys were trying to use.
Old May 26, 2003 | 06:11 PM
holyshithatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project91REXSi &raquo;</TD></TR><TR><TD CLASS="quote">Yep, that was what I wanted to do...why doesn't it work? I guess now that I think about it, if it worked people wouldn't do full ZC powertrain swaps...duh </TD></TR></TABLE>
yeah, buddy, duh
Old May 26, 2003 | 06:14 PM
FourthGenHatch's Avatar
Default Re: Will DOHC ZC head work on my D16A6 block? (holyshithatch)
If it was possible more people would have done it already. All the people that say it can be done please show us some proof, until then don't be so cocky and say people that say it can't be done are morons.
Tyounin608
Dec 21, 2006 08:37 AM
jdmspeck
Jan 4, 2005 08:46 AM
porschekremer
May 3, 2004 08:04 PM
Stunna BEN
Oct 11, 2003 11:11 AM
ITR1071
May 26, 2002 08:15 PM
