GSR rear trailing arms same as ITR ?
Old May 26, 2003 | 01:11 AM
Danger's Avatar
Default GSR rear trailing arms same as ITR ?
are they the same ? would it be possible to swap a 5 lug hub / rotor /caliper onto a gsr trailing arm ?
thanks
Old May 26, 2003 | 05:45 AM
Benbuilt4u's Avatar
Default Re: GSR rear trailing arms same as ITR ? (JonnyDanger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonnyDanger &raquo;</TD></TR><TR><TD CLASS="quote">are they the same ? would it be possible to swap a 5 lug hub / rotor /caliper onto a gsr trailing arm ?
thanks </TD></TR></TABLE>
i have a post up with the same basic question and so far the answer is NO. i am trying to change just my rears because i got fronts with my JDM itr swap. I ordered a mostly complete rear suspension from a junk yard for $250.00. but i need both calipers one hub and 2 rotors.
Old May 26, 2003 | 07:13 AM
B18C5's Avatar
You can do it if you grab the spindle too. Only thing is it uses those weird starish key things and I think they're there for a reason. You might as well grab the whole trailing arm. Good thing about that is you get the good ITR trailing arm bushings going that route.
1998b18c1
Mar 15, 2007 10:21 PM
AlienKrOZ
Oct 2, 2006 08:24 AM
NXSpoon
Aug 7, 2006 12:55 AM
Lissav
29
Mar 17, 2006 11:07 AM
One Bad GeeSeeR
Jun 24, 2004 02:49 PM
