rotar bolts
Old May 25, 2003 | 09:57 PM
chirp2hrd's Avatar
Default rotar bolts
i cant get the bolt under the rotar off it seems to be moving with the screw does this mean i need an impact gun...cause i got the other side off
Old May 25, 2003 | 11:13 PM
civickiller's Avatar
Default Re: rotar bolts (chirp2hrd)
what, repeat more clearly
Old May 25, 2003 | 11:26 PM
RCautoworks's Avatar
Default Re: rotar bolts (civickiller)
Do you mean the castle nut by the lower ball joint ? If you do it slowly or maybe use vice grips, you could get it off like that.
Old May 26, 2003 | 12:07 AM
blah13's Avatar
Default Re: rotar bolts (90blackcrx)
Heres a trick I used when taking mine off and putting it back on, I'll also assume you got the castle nut to where you still have the hole visable....get some thin wire, run the wire through the hole in the bolt and bend it down to where it wont be in the way of the castle nut and twist it together clockwise. Grab some vice grips and clamp them on the wires. While holding the vice grips loosen the nut with an open end wrench and it shoudl come off or get loose enough to where its not biting on the bolt and causing the joint to spin. Kinda hard to explain but its the best I can do.
Old May 29, 2003 | 09:44 PM
chirp2hrd's Avatar
Default Re: rotar bolts (blah13)
ill try that thanks
chillerice
Suspension & Brakes
May 20, 2013 02:28 PM
00DC2
Jul 22, 2009 06:18 PM
Integra4lyfe069
Apr 28, 2009 12:09 PM
Hartlage
13
Jun 16, 2003 03:22 PM
DreamSpeed
Oct 29, 2001 05:07 AM
