HELP! My clock resets everytime!
Old May 25, 2003 | 08:01 PM
Mashimaro's Avatar
Default HELP! My clock resets everytime!
Hey guys/gals,
I've got a '93 Si and everytime i start my car, the clock starts at 1:00! When the car is off, the clock doesn't seem to have any power running to it. I hold down the little plastic flap which usually shows the time (without the car running/key in) but nothing happens...anyone else ever had this problem? any help would be appreciated..thanks!
Old May 25, 2003 | 08:02 PM
moondoggy's Avatar
Default Re: HELP! My clock resets everytime! (Mashimaro)
does your radio station resets itself?
Old May 25, 2003 | 08:04 PM
Daniel's Avatar
i had this problem with my old Accord. it turned out that the LED was dead. but the car was also 11 years old at the time, so that would explain it. Maybe your LED is dead, too.
Mashimaro's Avatar
nope, my deck is fine, the clock on the deck doesn't reset itself nor do the preset stations...
oh yah, is the clock connected in any way to the rear defogger switch? the little light that indicates that it is on doesn't always work....
Old May 25, 2003 | 08:05 PM
Mashimaro's Avatar
Default Re: HELP! My clock resets everytime! (Daniel)
funny thing is, the LED light works when the car has started...it just starts at 1:00 and then starts counting up normally...??
Old May 25, 2003 | 08:23 PM
steve_meyer's Avatar
Check the "backup" fuse in your engine bay fusebox.
Old May 25, 2003 | 08:24 PM
Mashimaro's Avatar
is it linked to the clock? thanks again for the help folks!
Old May 25, 2003 | 08:53 PM
Mashimaro's Avatar
steve_meyer
THANK YOU SO MUCH DOOD! I just took a look at the fuse box and low-and-behold the 7.5fuse that was there was blown! changed the fuse and now my clock works again!!
Thanks for all the help guys, my car is an Si once again! =D
Old May 26, 2003 | 02:48 AM
ShakesTheKlown's Avatar
Default Re: (Mashimaro)
Is it a "backup" as in spare fuse? Or is it a fuse labeled backup... I've got the same problem in my EX... And it gets really dim when I turn on my headlights, and blinks a bit when my turn signals are on...
Old May 26, 2003 | 07:02 AM
Ricey McRicerton's Avatar
Default Re: (ShakesTheKlown)
Nope, the backup fuse is not a spare. It is what holds information for the radio presets, clock, and the ECU (BTW, thats how the Helms manual says to reset the ECU...just pull the backup fuse for 20 seconds). It is clearly labled on the underhood fuse box!
Old May 26, 2003 | 11:00 AM
4DRPIMPIN's Avatar
just run 12v constant to the clock..
Neo858
Oct 8, 2014 12:11 AM
Johnnie
Dec 3, 2007 09:36 PM
scotch_taped
Jul 21, 2007 09:20 AM
EH-3
Feb 7, 2006 09:50 PM
integration
Oct 7, 2003 01:05 PM
