tranny problem?
Old May 25, 2003 | 03:22 PM
BoostedsiR's Avatar
Default tranny problem?
I hear I noise it sounds like something is spinning roughly inside my tranny I think it could be the throw out\ release bearing and or pilot bearing, I got a clutch masters stage 3 clutch and pressure plate where can I get this how much do they cost, can it be a generic bearing, Pulling tranny's suck. when I push the clutch in most of the noise goes away and it makes a slight noes could that be my differential? My axles are brand new. Im just trying to give you guys a better possability for a better diagnosis.
Thanks
Old May 25, 2003 | 04:30 PM
BoostedsiR's Avatar
Default Re: tranny problem? (BoostedsiR)
bump can somebody help me
Old May 31, 2003 | 06:14 AM
RickChew's Avatar
Chances are it is your throwout bearing. My tranny was doing the same thing. Was it replaced when you last replaced your clutch? I just had mine swapped out and the noise went away....but now its making a noise when the clutch is not engaged..arg! good luck w/ the tranny! Rick
Old May 31, 2003 | 08:38 AM
JDMH22HATCH's Avatar
Default Re: tranny problem? (RickChew)
It could be the bearing in the tranny casing. They have a tendecy to go out, especially with B-series transmissions. Usually when they go out, it sounds like something is vibrating or kind of squeeling while driving.
Old May 31, 2003 | 05:28 PM
RickChew's Avatar
Default Re: tranny problem? (JDMH22HATCH)
If its squealing its most likely the throwout bearing. If it grumbles its the imput bearing. Rick
H22_CB7_JAY
17
Feb 15, 2013 06:48 PM
vlc92189
Jul 23, 2006 05:01 PM
JDM SLICK
Feb 15, 2005 11:17 PM
ATS*Mark
12
Jul 1, 2003 07:17 AM
AzntaggeR
Mar 13, 2003 03:18 AM
