2002 Civic Si sway bars on a 2002 Civic coupe?
Old May 25, 2003 | 03:10 PM
00TEG's Avatar
Default 2002 Civic Si sway bars on a 2003 Civic coupe?
I was wondering if the sway bars on the 2002 Civic Si will bolt directly up to a 2003 Civic Ex coupe? I know if it will I will have to get new bushings but I was wondering if I would have to get new D brackets or end links. Also, should I have to worry about the subframe? I know it was somewhat an issue with my Integra LS b/c it was not bolting to a flat surface. I took care of this with the Comptech sway bar and tie bar set and have had good experience with it, but I would rather not spend as much money with these sway bars. Thanks for all help.
Old May 26, 2003 | 07:24 AM
00TEG's Avatar
Default Re: 2002 Civic Si sway bars on a 2003 Civic coupe? (00TEG)
I'm sure there is someone who would know this. Any help with this would be nice.
Old May 26, 2003 | 08:00 AM
Targa250R's Avatar
be professional
Sory, don't know the answer, but I can tell you that RSX-S sway bars are more desireable than those from the Civic Si.
Free bump for you.
Old May 26, 2003 | 10:43 AM
RickChew's Avatar
Default Re: 2002 Civic Si sway bars on a 2003 Civic coupe? (Targa250R)
Try the EP3 forum. Rick
theguy22
Suspension & Brakes
13
Aug 19, 2018 08:02 PM
96 EX
25
Jun 2, 2009 01:31 PM
SoullessJapaneseMachine
Suspension & Brakes
Oct 10, 2007 07:43 PM
00TEG
May 28, 2003 02:04 AM
tominos
Dec 3, 2002 09:23 PM
