Need Help
Old May 25, 2003 | 10:01 AM
Flux's Avatar
Default Need Help
I'm installing SS lines (finally). How do I get the OE brake line disconnected from the clip in the wheel well (right after connecting to the hard line)?
Need help now please.
Old May 25, 2003 | 10:02 AM
NXSpoon's Avatar
Default Re: Need Help (Flux)
It is a C-clip. Get a pair of large jaw pliers, clamp on the raised lip, and PULL towards you.
Old May 25, 2003 | 10:04 AM
.RJ's Avatar
.RJ
Default Re: Need Help (NXSpoon)
Or slip joint plyers. Spray some PB blaster in there too, that helps.
Old May 25, 2003 | 10:06 AM
uNF$@#!'s Avatar
Default Re: Need Help (.RJ)
...and when disc the original brake lines, the size is between a 9mm and 10mm, so i'd say use an adjustable wrench
Old May 25, 2003 | 10:27 AM
Flux's Avatar
Default Re: Need Help (Soup ****)
Thanks guys...
Do the holes in the banjo bolts need to be facing a particular direction? Logic tells me they should be up and down put the helms says nothing about that...
Old May 25, 2003 | 10:30 AM
.RJ's Avatar
.RJ
The orientation of the banjo fittings should be dictated by the orientation of the line once the brackets are in and the notch in the caliper for the line, i.e. it only wants to go in one way but it doesnt matter which.
Old May 25, 2003 | 10:31 AM
NXSpoon's Avatar
I thought about them for a little bit when I put on my SS lines.....and then I just torqued them down. No problems yet, and I don't expect any.
Just do a THOROUGH bleed job, and then again a few days later after everything is bedded in. Mine felt spongy at first, but as the pads set in, it firmed up a little. After the second bleed, it was as firm as I expected.
Old May 25, 2003 | 01:03 PM
Flux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">The orientation of the banjo fittings should be dictated by the orientation of the line once the brackets are in and the notch in the caliper for the line, i.e. it only wants to go in one way but it doesnt matter which.</TD></TR></TABLE>
Thanks. I'm not talking about the banjo fitment but the bolt itself. There is a hole running perpindicular through the bolt, does this need to be lined up with something or can I just put the bolt on and torque it down?
Old May 25, 2003 | 01:10 PM
.RJ's Avatar
.RJ
Put it in and torque it down
hondazccivic
Aug 21, 2008 11:41 AM
Easy Eddy
Aug 18, 2006 01:16 PM
ill phil
Aug 6, 2003 11:52 PM
buck02
Mar 3, 2003 11:45 AM
