did swap need help bad!!!
Old May 24, 2003 | 09:05 PM
rkn527's Avatar
Default did swap need help bad!!!
i put a 96 ls into my 93 coupe but the header flange and the cat flange dont line up.
i have noticed that the rear motor mount doesnt match up what can i do
Old May 24, 2003 | 09:13 PM
TurboTeG4's Avatar
Default Re: did swap need help bad!!! (rkn527)
bump
What bout a b18c1 into a 93 coupe with drag turbo will the flange match up?
bump
Old May 24, 2003 | 09:29 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: did swap need help bad!!! (turbocivic4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic4 &raquo;</TD></TR><TR><TD CLASS="quote">bump
bump</TD></TR></TABLE>
the drag kit has no flange. just a 2 1/2" hole.
as far as the rear mount not working, did you use the rear mount off of a del sol vtec? a 99-00 Si mount is too short. wont work. as for the flange, os ot 90 degrees off? i have had to cut and weld a few. or is it too long? or short? i think the GS-R cats are a little different.
BoostGoneWild
Nov 12, 2007 02:25 PM
projectpd
May 14, 2007 10:30 AM
stackz
14
Jan 2, 2007 01:43 PM
B18civic5g
Jan 8, 2005 12:54 PM
Rhythm
26
Sep 23, 2004 06:52 PM
