no spark no fuel pump after big time work done 1990 ex 2.2
Can't get fuel pump to run,or spark to plugs. What I'm I not doing right. Check engine light will not come on at proper time with key. did head gasket/timing belt ect. GOD BLESS
One thing you don't mention, is it cranking good and strong?
With both the fuel pump and no spark, like the other guy said, check fuses. Also check grounds and such in the engine bay, perhaps you forgot to reconnect a ground or something.
Does the rest of the electrics come on inside the car? If not, is your battery connected?
jk
jk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocky2 »</TD></TR><TR><TD CLASS="quote">Can't get fuel pump to run,or spark to plugs. What I'm I not doing right. Check engine light will not come on at proper time with key. did head gasket/timing belt ect. GOD BLESS
The main relay will cause the symptoms you are mentioning. Might wanna look into that. It will cause you to NOT have spark as well as NOT have fuel.
</TD></TR></TABLE>The main relay will cause the symptoms you are mentioning. Might wanna look into that. It will cause you to NOT have spark as well as NOT have fuel.
On my '94 Accord when i put it back together this past weekend, i didn't hook up the second ground to the throttle body, and had no fuel, not sure if i had a spark or not, i figured it out rather quickly.
trav143
11
Oct 8, 2008 10:58 AM
