LS or GSr for turbo
I was wondering whats better for turbo a LS engine or a gsr. since vtech is disabled with turbo whats the point of the gsr. I plan on fully building the engine.
Who ever told U that VTEC is disabled with a GSR? That is Not true, some people think they make more power without it but I dont know if that is actually true. A GSR block is better because:
1. It has a more aggresive cam profile(In VTEC mode)
2. It has oil squirters that squirts oil on the back of the piston which helps to cool the piston.
3. It is a stronger block.
4. Lots of parts are available, its very popular. and more
I agree with the statements about the block.
However, the part about VTEC being disabled is where I differ slightly.
When the VTEC lobes on the cam engage, you end up with a slight valve overlap. Or both sets of valve being open for a split second at the same time. Now this is great on a N/A motor because it helps create a more powerful vacuum in effect pulling more air into the cylinders. On aboosted car, since you are forcing air into the cylinders already, you do not need this effect. In reality, you are actually, for a split second, pushing air out of the cylinder by way of the exhaust valve. Now, a set of cam gear can help you tune the cams to get rid of that small problem. If you want to take it a step further, a set of roller rockers will keep you on those VTEC lobes at all time and let you rev much quicker and higher. Combine those with some cam gears on the GSR motor and you have a hell of a turboed car.
edit - personally, I would go with the B18C over the B18B.
[Modified by Big James, 9:14 AM 7/13/2001]
I'm not sure about the technical sides of these things.. but Nfurno (LS integra) dyno'd his car and got about 220 on a realtively stock setup... another couple people on here with a GSR got roughly 260...
I'm pretty sure it was the more aggressive "vtec" profile that helped get the extra power..
a little overlap is ok, but I wouldnt go get crazy cams with tons of overlap.
Stock for stock, the LS is better because you can boost at a higher rate. The LS is a lower compression motor, therefore, it only makes sense.
But, if you build a GSR block, it will make more power than an LS motor, especially with that high RPM.
It's a simple answer, the GS-R motor will outperform the LS. The LS head simply cant flow as much air as a GSR head. Now If you're on a budget then you might consider an LS motor. For the price of a stock GS-R motor I can build an LS motor that will run circles around the GSR. But if money isnt a concern then of course go with the GSR motor.
persoanlly, i think its all a matter of how crazy you want to get.
bolt on kit, ~7 psi or so, slightly mod'ed or stock internals, the gsr will kick an ls's *** pound for pound.
However, for high boost aplications, you will see me NO WHERE near a vtec engine. Think about it more like this-- A gsr has 10.x:1 compression. who cares? if your gonna bOOst it, your gonna build it and drop that to at least mid 9:1's. but what vtec SUCKS in turbo set ups is not the electronic lift control- its the variable timing part. In effect, on the vtec cam, the timing is advanced. And boost, well- it likes retarded timing. so, what you are doing is fighting each other-- and that leads to problems that i know I don't want to deal with.
Hence, why I'm currently building an LS for boost to go in my del sol. shootin for 300 WHP when im done, in a daily driver/only driver format.
to each his own, but I would NEVER boost a vtec more than 7.
as for the variable lift part u were talking about... i dont know the exact details of it... but i know it works and i have seen it done over and over... vtec heads makeing more power than non-vtec heads
justmotor13
Feb 13, 2003 09:00 PM
