My turbo GSR is running way too rich...help
Old May 24, 2003 | 12:14 PM
Ryan C's Avatar
Default My turbo GSR is running way too rich...help
i have a GSR turbo runnig on 310cc, a 255lph in tank , a b&m FPR,and a 12:1 vortech FMU. The FPR is turned down ALL THE WAY and i still am running 50lbs at idle! my car is running so rich it is ridiculous. I ordered 8:1 and 10:1 dics to help lean the mixture but that wont affect my pressure at idle. do i need a new FPR or is the b&m a POS?~!
TIA
Old May 24, 2003 | 12:38 PM
sleepy's Avatar
Default Re: My turbo GSR is running way too rich...help (Ryan C)
Possible solutions with your FMU setup.
1. VAFC will work wonders.
2. Ditch the B&M and get SX fpr aka Aeromotive
3. Get it tuned by someone who knows what he is doing.
4. Lastly. Get Hondata OBD1 at the lowest level and sell all the FMU related stuff.
Good luck.
Old May 24, 2003 | 02:17 PM
TeStUdO's Avatar
as far as i know the b&m is only a fuel pressure riser therefore you cant lower fuel pressure. im not 100% positive though
Old May 24, 2003 | 02:32 PM
x2gold's Avatar
Default Re: (TeStUdO)
hey Ryan, where did you get 310cc injectors? Are they from a celica GT-S? If yes, how did you get them to work with your intake? I'm just curious because i picked up a set of celica injectors. Thanks
Old May 24, 2003 | 04:29 PM
Tweakmeister's Avatar
Default Re: (x2gold)
you should be able to get a little less than 50 out of the b&m.
Is there anything inside the FPR? Are you sure you're setting it with the vacuum line off?
A v-afc should be able to help in this situation as a cheap fix.
Old May 24, 2003 | 07:27 PM
Ryan C's Avatar
Default Re: (Tweakmeister)
yes, i was adjusting it with the vacumn line off.
and the 310cc injectors are from RC engineering
Old May 24, 2003 | 07:50 PM
VisualAutoMotoring's Avatar
Default Re: (Ryan C)
yea most definetly, get a better regulator..not saying the B&M aint good but something better....
stay away from AEM is you can...
i had a bad experience once...
FMU 12:1 w/AEM FPR....my car was just dumpin fuel to the point i couldnt crank it...goes to show the FMU shot the diaphram in the FPR so it was dumpin too much fuel
50 psi @ idle is tooo much....i only run about 37-42psi
Old May 24, 2003 | 08:25 PM
tony1's Avatar
Default Re: (KurumaTuning2)
That's kind of a common problem when running an intank and inline pump. The return part of the factory regulator can't bypass enough fuel to bring the pressure below 50psi. You need to get an afc and tune the fuel curve that way. Even if you get an aeromotive regulator and turn it down, then whole map will still be too rich. You can't go too low on the fuel pressure or the injectors won't operate right.
Old May 25, 2003 | 09:02 PM
Ryan C's Avatar
Default Re: (tony1)
couldnt i just get the aeromotive FPR and a 8:1 or 10:1 disc skip the AFC and save up for hondata?
do you thinks its possible that the pressure broke the FPR?
Old May 25, 2003 | 10:47 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">couldnt i just get the aeromotive FPR and a 8:1 or 10:1 disc skip the AFC and save up for hondata?
do you thinks its possible that the pressure broke the FPR?</TD></TR></TABLE>
Yes....
The b&m is a fuel pressure riser. Once you add an aftermarket fuel pump it cannot lower the fuel pressure low enough. The stock return orface is to restrictive.
You can also run a aem fpr to lower your fuel pressure. I'm runing a 255lph pump and had to buy a aem fpr to drop my fuel pressure down to about 40psi. I've been runing it for ove ra year with no problem.
Buying anything but an actual fpr that can flow enough will NOT remidy this problem (v-afc etc..)...
8:1 fmu is what most generally run with 310cc injectors. I am runing a 4:1 though strange but thats what works for me........(310cc injectors also)
Old May 26, 2003 | 06:44 PM
Ryan C's Avatar
Default Re: (b16ahybrid)
thanks hybrid
thats the kind of answer i was hopin for
Old May 26, 2003 | 08:36 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">thanks hybrid
thats the kind of answer i was hopin for</TD></TR></TABLE>
Anytime!
Turboteg00
Mar 19, 2008 02:46 PM
nfinitecc
Dec 4, 2005 02:45 PM
taejin11
Jun 20, 2004 09:45 PM
CBR600OnTop
Feb 28, 2003 09:54 PM
integraracer94
May 19, 2002 09:12 PM
