Oil Temp Sender... Good Idea or Bad Idea?
Old May 23, 2003 | 06:22 PM
94TealGSR's Avatar
Default Oil Temp Sender... Good Idea or Bad Idea?
I just got my electrical oil temp gauge, and I'm looking to hook it up. I was thinking of just drilling a hole in my oil pan and welding on the matching nut and screw in the sending unit.
Is this a good idea, or bad idea? I don't know much about how the electrical gauges work; I saw a couple of threads about them grounding out. What are the guidelines for these things?
My OEM oil sensor is kinda screwed, so I could just buy the adapter and put it in there. I'd rather do it from the oil pan because that's a bit more along the lines of what I want.
Thanks again.
Old May 23, 2003 | 07:53 PM
bxsi's Avatar
Old May 24, 2003 | 03:19 PM
krazy's Avatar
Default Re: (bxsi)
use the hole near the distributor. its a 12mm bolt with 10mm thread, right above the left most exhaust manifold stud. works fine. use silicone too, so it wont leak.
krazy
Old May 25, 2003 | 06:41 AM
94TealGSR's Avatar
Default Re: (krazy)
I used the one on the back of the head, and I used teflon tape. Seems to have sealed very well.
Now I just have to figure out why the car sat overnight, but immediatley upon turning the key the gauge read 150F... pretty sure my oil wasn't 150 degrees after sitting overnight... I think... right?
Old May 25, 2003 | 02:20 PM
krazy's Avatar
Default Re: (94TealGSR)
make sure the sender is grounded and the guage itself is grounded. if not, it bounces around. the teflon tape may not have grounded it properly.
krazy
KStuned
Mar 13, 2004 12:33 AM
onyx00
May 14, 2003 06:22 AM
Hondasaurs
May 1, 2003 06:02 PM
BoostedH23a1
Oct 28, 2002 08:34 PM
