oil temp sender in oil pan ok??
Re: oil temp sender in oil pan ok?? (BoostedH23a1)
Why don't you just tap it and use thread sealant or teflon paste/tape? Wouldn't it be kinda stuck there if you brazed/welded it? What if you need to swap pans for some reason? I guess you could just buy a new temp sensor.
Re: oil temp sender in oil pan ok?? (inspyral)
greddy has a kit out already tapped with holes for a feed line as well as a gauge.
[Modified by GudeH23a, 12:34 AM 10/29/2002]
Re: oil temp sender in oil pan ok?? (GudeH23a)
TrueUntilDeath.com
02-12-2005 10:13 PM
