need to take off crank pulley
Old May 23, 2003 | 11:18 AM
zccrx's Avatar
Default need to take off crank pulley
how do i do it. how do i take that pulley off i tryed with my impact and breaker but where do i hold the motor from so it wont turn, whats the trick to it. i put the timing belt wrong when i put in the new belt i know i feel like a moron so any one with answers please help me out oh the motor is in the car its a zc motor i can do it with it inside right
Old May 23, 2003 | 11:20 AM
shortyz's Avatar
Default Re: need to take off crank pulley (zccrx)
yeah that bolt is a real bitch.
take the starter off and jam a big *** chisel in there.
then take your breaker bar and put a piece of pipe and wedge it against the ground with the car in the air. lower the car so itll loosen the bolt.
also your gonna fuckup sockets if your not using 1/2 impact sockets. good luck
o another trick u can use to jam the motor is put nylong rope it in the cylinder from the spark plug hole, old v8 trick.
Old May 23, 2003 | 11:45 AM
GroundZer0's Avatar
Default Re: need to take off crank pulley (shortyz)
This is a giant bitch, i had to take this off once. What you need to do is get a new socket, of a good good brand, i think i used snap-on or something. Then what you need is a HUGE breaker bar, and i basically had to jump on the *****, no joke, to get it off. You may try heating it up, or using some sorta lube, but man this is a bitch, good luck! Not even an impact worked for me.
Old May 23, 2003 | 12:00 PM
StlSupra's Avatar
proper sized socket with big breaker bar. BAS (big *** screwdriver) wedged into flywheel teeth. full wieght on the breaker bar will turn it.
Old May 23, 2003 | 12:14 PM
therealciviczc's Avatar
IR2131 impact gun. A 250 lb/ft gun isnt' going to cut it.
You can also take off the flywheel inspection plate and bolt the flywheel to the bell housing. I have heard of that breaking the bell housing, but its very unusual.
Old May 23, 2003 | 01:31 PM
yellowcrx1991's Avatar
https://honda-tech.com/zerothread?id=497961
Old May 23, 2003 | 02:24 PM
7PSI CRX's Avatar
Default Re: need to take off crank pulley (yellowcrx1991)
Either the screwdriver in the flywheel,
Or
a home-made pulley holder....
and the proper tools....
and *The Secret Weapon"....
Will do it every time.
Old May 23, 2003 | 04:02 PM
EF'n's Avatar
i have done many of these, i was using what we call the "top gun" it is a big *** impact hammer gun. i finially bought the morroso honda/acura crank pully tool, works great. i highly recomend buying one. no power tools needed, just put this baby on and it will hold the crank from turning and you put your socket thruogh the hole and use a breaker bar and presto, its off.
Old May 23, 2003 | 04:18 PM
joey1320's Avatar
Default Re: need to take off crank pulley (revhardracing)
Use the 325lbs impact gun... it works like magic.
I just took mines off 2 weeks ago.
socialistic
31
Jun 26, 2011 12:54 PM
EvilPinkEye
12
Aug 2, 2006 11:51 AM
patentguy
Feb 2, 2006 12:03 PM
94CivicSi
Aug 23, 2002 01:25 PM
Renegade
May 24, 2002 06:18 PM
