Clutch Noise
Old May 23, 2003 | 06:09 AM
inty2511's Avatar
Default Clutch Noise
I've been having this noise for a couple of months now, there's a chattery/ringin noise but when you press on the clutch it goes away, it doesn't happen all the time, i searched and found out that it is most likely a bearing or something. Well i brought the car to the dealership to get it checked and they said that it was my intake, and to further check it i have to put the stock intake back. I don't have the stock intake anymore and i think i'm just gonna let it go till i have enough money for a new clutch, do you guys think it'll be ok to let it go for now or will the sound get worse. thanks
Old May 23, 2003 | 11:02 AM
JimBlake's Avatar
Default Re: Clutch Noise (inty2511)
Sounds like your throw-out bearing. If it was the intake it wouldn't change when you pressed on the clutch pedal. It'll probably keep getting worse. I think most of the time it gets so bad that people can't stand it any more, before it actually breaks...
Old May 23, 2003 | 11:32 AM
Dan GSR's Avatar
try adjusting your pushrod on the clutch....try turning it out serveral times.
beoy9
Nov 1, 2007 01:52 PM
oscar_lopez03
Jan 8, 2005 01:57 AM
avex
Oct 26, 2003 09:54 AM
Mikey
Jul 5, 2003 09:52 PM
hooptie157
Dec 22, 2002 02:04 AM
