Help please: need some advice on the best valve clearance
Old Jul 12, 2001 | 04:31 PM
R8dR's Avatar
New User
Default Help please: need some advice on the best valve clearance
When I had my valve clearances adjusted by a mechanic about a year ago, the car didn't feel quite as fast as it used to. But I dismissed it as just my imagination. The car was due for another adjustment, so I thought I'd try to do it myself for the first time. I figured I'd be more critical on making sure the clearances were all precise. I measured the exhaust clearances 0.009 and the intake sides were around 0.008. So I readjusted them to 0.007 exhaust and .0006 intake. When I took the car out for the test drive, I noticed that it runs alot smoother and the acceleration is definately better. Everything went pretty smooth so I gave myself a pat on the back.
Finally, here's the questions I have... I'm wondering if I go even tighter (.005 intake and 0.006 exhaust) if I'd get more hp gains. I read somewhere on the Endyn board that people were running clearances tighter than Honda spec and getting noticible gains. Has anyone tried this on the ITR and gotten any gains? And is it safe on the ITR?
[Modified by R8dR, 1:55 AM 7/13/2001]
Old Jul 12, 2001 | 06:07 PM
Michael Delaney's Avatar
Default Re: Help please: need some advice on the best valve clearance (R8dR)
he lists the min. clearances here: http://www.theoldone.com/articles/en...DataSheet.html
rocker wear is a consideration. The tighter the lash the longer the cam lobe sits on the rocker and gives you a slight increase in overlap.
Old Jul 13, 2001 | 02:34 AM
R8dR's Avatar
New User
Default Re: Help please: need some advice on the best valve clearance (Michael Delaney)
Michael - thanks for the reply. Can you please clarify... You can go a little tighter safely but at the expense of more wear and tear? And increasing overlap will increase hp? I'm thinking about going 0.001 to 0.002 tighter, but I'm worried that the cam lobes would ALWAYS be touching the rockers once the engine is running at temp.
sick_dc2
Nov 22, 2008 01:33 AM
1badteg
Jun 25, 2007 10:28 PM
96tegsr
Jan 18, 2003 05:53 AM
raene
Jun 25, 2001 10:29 AM
