Ecu reset switch??
Old May 22, 2003 | 11:24 PM
Frankie324's Avatar
Default Ecu reset switch??
Not for security reasons, but to reset the ecu for obd2 cars.
I have a h22a w/no cat and i get a check engine light everyother day after i reset.
my question is there a way that i can hook up a switch to reset the ecu without pulling the neg battery cable?? 1st its a PITA with the radio and poping the hood gets old.
with a multimeter i found more than 1 12v source going into the ecu, is there anyway to do this????
Old May 23, 2003 | 12:06 AM
b19coupe's Avatar
Default Re: Ecu reset switch?? (Frankie324)
You could do it fairly easily. There should be only one 12 volt source to the ECU with the ignition off, that would be for the ECU memory. Put a switch on that wire and you are done.
g-dan90
Apr 19, 2010 04:57 PM
Etorres325
Mar 5, 2010 10:36 AM
pimpdd101
Mar 5, 2009 07:46 AM
eLeCtRoNSi00
Apr 16, 2004 01:17 AM
Reddog
Jan 12, 2003 10:42 AM
