Oil pressure gauge installation question
Old Jul 12, 2001 | 02:48 PM
Ibuprofen's Avatar
Default Oil pressure gauge installation question
could you guys please tell me how to wire an electrical Autometer oil pressure gauge? thanks
Old Jul 12, 2001 | 02:52 PM
HapaHaole's Avatar
Default Re: Oil pressure gauge installation question (ITyp3R)
its one sending wire see pic yoshi posted below. then the rest of the wires are done inside the car. the pic is what i run on my racecar
Old Jul 12, 2001 | 02:55 PM
yoshi234's Avatar
I shoot brides
Default Re: Oil pressure gauge installation question (yeah LS)
Old Jul 12, 2001 | 03:35 PM
Ibuprofen's Avatar
Default Re: Oil pressure gauge installation question (yoshi234)
wait, is that an mechanical oil pressure gauge or electrical oil pressure gauge?
Old Jul 12, 2001 | 03:36 PM
HapaHaole's Avatar
i thought i said wire??? electrical mang
the mechanical one is small not like that bigol sender
Old Jul 12, 2001 | 09:08 PM
Ibuprofen's Avatar
Thanks for the info LS, i appreciated it. still a lil clueless on wiring though..
Old Jul 12, 2001 | 10:18 PM
slowerthanu's Avatar
New User
I had the Autometer and it broke creating a nasty mess behind the motor. I have a greddy now and the Quality differance over autometer is fawking unbelievable.
Old Jul 13, 2001 | 08:50 AM
HapaHaole's Avatar
Default Re: Oil pressure gauge installation question (slowerthanu)
gage:
one wire to the sender
one wire to ignition power
one wire to ground
bulb:
one wire to lights
one wire to dimmer if you have that, if not ground
sender:
wire from gage
and thats it!
Old Jan 11, 2005 | 10:59 AM
SamC's Avatar
Default Re: Oil pressure gauge installation question (ITR for sale)
yoshi234,
do you have another pics where the sender unit is? thanks
Old Jan 11, 2005 | 11:06 AM
jdmspoonitr's Avatar
Default Re: Oil pressure gauge installation question (SamC)
Autometer anything = Bleh
Old Jan 11, 2005 | 11:09 AM
Willard's Avatar
the serch engine is a POS right now... but Nick had a nice pictoral with his install.
https://honda-tech.com/zerouser...10285
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">Autometer anything = Bleh</TD></TR></TABLE>
anything is better than nothing.
Old Jan 11, 2005 | 09:57 PM
Opie's Avatar
Default Re: Oil pressure gauge installation question (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">Nick had a nice pictoral with his install.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=801990
Old Jan 12, 2005 | 05:17 AM
Philly_NBP_R's Avatar
Default Re: Oil pressure gauge installation question (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=801990
yeah, Greddy Quality =
I've had zero problems with my Greddy gauges since I installed them last spring...
Old Jan 12, 2005 | 09:44 AM
SamC's Avatar
Default Re: Oil pressure gauge installation question (Philly_NBP_R)
is the Greddy Oil Block Adapter required to install the oil pressure guage?
Old Jan 12, 2005 | 11:24 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SamC &raquo;</TD></TR><TR><TD CLASS="quote">is the Greddy Oil Block Adapter required to install the oil pressure guage?</TD></TR></TABLE>
nope... you can remove the stock sending unit and put an aftermarket unit in the same hole... as long as the threads are the same. you will loose oil pressure light on the dash if you remove the stock unit.
the stock sending unit is right beside the white-ish bolt that is holding the cv shaft bracket
Old Jan 12, 2005 | 12:27 PM
SamC's Avatar
Is this the Greddy kit that would work on our cars?
http://www.importparts.com/sho...=2536
Old Jan 12, 2005 | 12:30 PM
that's not the exact one that I had, but it'll work. So - yes - it will fit your car...
here is the part number and description of the piece that I ordered and installed (from importparts.com):
Products
1 x Greddy Oil Block Adapter UNIVERSAL M20 X P1.5 70 (Honda,Mazda,Mitsubishi & Subaru) (GRE-12002733) = $57.80
Old Jan 12, 2005 | 12:46 PM
SamC's Avatar
Philly_NBP_R, the no longer carry that from Greddy.
Is either the universal Greddy one or the AC one:
http://www.importparts.com/sho...=1641
Which one would you guys suggest?
Old Jan 12, 2005 | 01:14 PM
Willard's Avatar
since the price is almost the same... I would go with GGGGGG-ready
Old Jan 12, 2005 | 01:52 PM
B2FiNiTY's Avatar
Go with the greddy
Old Jan 12, 2005 | 03:32 PM
GPNY's Avatar
Default Re: Oil pressure gauge installation question (B2FiNiTY)
I teed my pressure fitting off the oil line to the turbo...
I believe Pressure is constant wherever you put the sender anyway and that pressure losses would be recorded no matter where you put the sender (Except if behind a restrictor).
Someone please correct me if I'm wrong.
Old Feb 4, 2005 | 09:05 PM
SamC's Avatar
Default Re: Oil pressure gauge installation question (GPNY)
Finally the greddy adaptor arrives. Got a few install questions:
Do I need to use both rubber gasket?
Which adaptor do I use? the shorter or longer one?
What do you guys use to secure the adaptor? loctike(sp?)? which kind?
What is the torque specs?
Thanks
Modified by SamC at 1:56 AM 2/5/2005
Old Feb 5, 2005 | 04:24 AM
mugenracer's Avatar
Yes use both to ensure a proper seal.
Only one will fit, I think its the longer one, but just figure it out yourself
You dont need any thing to secure the adaptor, place the plate on the filter location, screw in the threaded tube piece.
I couldnt find any torque specs on the instructions as mine came from japan and the instructions were all in kanji, so i just tightened it good and tight with a ratchet and screwed on the filter (hand tight plus half a turn)
Screw in the sensors before you fit the plate onto the filter location as once fitted you have very little room to work at it. I used teflon tape around both sensors just to be sure, but they were a pretty tight fit without it and so its possibly not needed.
Once i had everything hooked up, i left the car on the lift and started the engine and let it heat up and then revved the crap out of it, raised the car to make sure there were no leaks. For a few days afterwards i also got a clean cloth and reached in behind the IM to wipe around the filter/adaptor plate to make sure there were no leaks....none so far, hopefuly it will stay that way.
Old Feb 5, 2005 | 05:10 AM
Default Re: Oil pressure gauge installation question (mugenracer)
I used "hondalock" - it's like locktite - on the threads for the sending unit (couldn't fit teflon tape...). As mentioned above, use both gaskets - it will ensure a good seal. Not sure of the torque spec, but basically, you need to torque it tighter than an oil filter - so it won't ever come loose...
I think you need the longer adapter, but I'm not sure - just test fit everything and it will be obvious.
Modified by Philly_NBP_R at 8:43 AM 2/7/2005
93egSLEEPER
Jul 12, 2009 04:54 PM
95dc2teg
Jan 31, 2007 10:48 AM
Nsane
Sep 16, 2006 04:36 PM
bosco500
28
Apr 25, 2005 05:07 AM
nyteflyte2003
Dec 3, 2004 11:26 AM
