SRS light flashin
Old May 22, 2003 | 04:41 PM
420aNT's Avatar
Default SRS light flashin
When I checked my 01 GSR for engine codes my SRS light kept flashing the whole time my engine light was flashing. Also the code that I got was a 24 but I don;t think there even is a 24. Anyones help is greatly appreciated.
Old May 22, 2003 | 04:46 PM
Chiovnidca's Avatar
Default Re: SRS light flashin (18gTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18gTeg &raquo;</TD></TR><TR><TD CLASS="quote">When I checked my 01 GSR for engine codes my SRS light kept flashing the whole time my engine light was flashing. Also the code that I got was a 24 but I don;t think there even is a 24. Anyones help is greatly appreciated.</TD></TR></TABLE>
I think the SRS light will flash steadily if there are no codes stored.
Code 24 huh? Was that 2 long flashes followed by 4 short?
Old May 23, 2003 | 12:27 AM
b19coupe's Avatar
The SRS light flashes when the SCS connector is shorted, that is normal. If the SRS light is not on under normal circumstances, (it should come on for 6 seconds after you start the car, and then go out) there is no problem in the SRS system.
Old May 23, 2003 | 03:49 AM
420aNT's Avatar
Default Re: SRS light flashin (Chiovnidca)
yeah it was 2 long and 4 short flashes. My car also is boosted and is running on Hondata with S100 & Boost if that makes a difference.
Old May 23, 2003 | 08:12 AM
b19coupe's Avatar
Code 2-4 is a short to power in the passenger's air bag inflator, according to the service manual. Clear it and see if it comes back.
Old May 23, 2003 | 10:25 AM
420aNT's Avatar
Default Re: SRS light flashin (b19coupe)
okay so how does this happen. I have never even heard of this before. I cleared my codes and it keeps coming back.
Old May 23, 2003 | 10:39 AM
b19coupe's Avatar
SRS should be warranty, try taking it to your local dealer and let them deal with it. If it is not covered under warranty, then go after the cause yourself. I have not seen this code myself-we see a lot of OPDS problems on Acura cars, also damaged cable reels and so forth.
Old May 23, 2003 | 11:19 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18gTeg &raquo;</TD></TR><TR><TD CLASS="quote"> Also the code that I got was a 24 but I don;t think there even is a 24. Anyones help is greatly appreciated.</TD></TR></TABLE>
Which light flashed this code? The CEL or the SRS?
Old May 23, 2003 | 12:58 PM
420aNT's Avatar
The check engine light was the one that flashed the code. The SRS was just steadily blinking the entire time. The car has zero warranty due to al the engine mods.
Old May 23, 2003 | 01:35 PM
b19coupe's Avatar
Well, you got me stumped. No code 24 in my service manual for the check engine light. If you are absolutely certain that the code it is flashing is a code #24, try another ECU.
Old May 23, 2003 | 01:39 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18gTeg &raquo;</TD></TR><TR><TD CLASS="quote">The check engine light was the one that flashed the code. The SRS was just steadily blinking the entire time. The car has zero warranty due to al the engine mods.</TD></TR></TABLE>
As far as I know that's not a valid code. Maybe someone with a Helms for your GSR can check. Could it be codes 20 and 4? How long is the pause between the long and short flashes?
Old May 23, 2003 | 03:16 PM
civicVX's Avatar
when your car is running which light stays on steady the check engine light or the srs light
Old May 23, 2003 | 07:15 PM
420aNT's Avatar
Default Re: SRS light flashin (civicVX)
when the car is running just the check engine light stays on constantly
Old May 24, 2003 | 08:10 AM
420aNT's Avatar
Anyone else have any ideas?
Old May 24, 2003 | 01:45 PM
420aNT's Avatar
bump
Old May 24, 2003 | 07:18 PM
civicVX's Avatar
so your positive 2 long and 4 short?
Old May 25, 2003 | 12:06 PM
420aNT's Avatar
yeah I am pretty sure
Old May 28, 2003 | 03:27 AM
420aNT's Avatar
bump
Old May 28, 2003 | 07:10 PM
420aNT's Avatar
okay so I finally think that I found my problem. I went to change my timing belt and one of the teeth on the crankshaft timing belt pulley is broken off. This had to be giving me the check engine light since the Cranshaft position sensor could not get a correct reading. Does anyone know if one off from an SI will fit on my 01 GSR?
Fns714
Jun 4, 2015 11:00 PM
eL
Oct 25, 2003 05:25 AM
vladd
15
Jul 17, 2003 12:52 PM
ITR624
Feb 27, 2003 09:25 PM
J T*
Feb 20, 2002 08:16 PM
