Brake noise question
Old May 22, 2003 | 03:39 PM
GQ Cowboy's Avatar
Default Brake noise question
I have changed my master cylinder and upgraded the brake lines to Stainless Steel. I have everything set up correct, but I noticed when I get in my car the morning after it has been sitting for awhile and when I press the brakes I can hear a loud "thudd" sound coming from the front calipers. Does anyone know what this might be? Are the Stainless Steel brakes lines producing to much pressure that when I apply the brakes the calipers are coming out to fast? Has anyone had this problem before?
Old May 22, 2003 | 03:54 PM
APEX CRX's Avatar
Default Re: Brake noise question (GQ Cowboy)
does the thud only happen when you first apply the brakes then go away after a few times?
Old May 22, 2003 | 10:20 PM
GQ Cowboy's Avatar
Default Re: Brake noise question (APEX CRX)
Yes the thud will only happen for the first initial press of the brake and then there after will be silent. My only opinion of what could be the problem is that the brake lines produce too much pressure that the brake piston shoots out for the first time. Anyone else know what might be happening?
Old May 23, 2003 | 05:34 AM
JimBlake's Avatar
Does it do this when you step on the brakes BEFORE you ever move the car, or does the car have to be moving?
Something (piston, pads, caliper slide pins?) is stuck in place with a little rust or something. You're breaking it loose when you first step on the brakes.
Old May 23, 2003 | 07:27 AM
turbochic's Avatar
Default Re: Brake noise question (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Something (piston, pads, caliper slide pins?) is stuck in place with a little rust or something. You're breaking it loose when you first step on the brakes.
Yeah I second that, thats what it sounds like..
Old May 23, 2003 | 09:44 AM
GQ Cowboy's Avatar
Default Re: Brake noise question (fmaxturbochic)
It only happens when I first apply the brakes, before the car is moving. Its odd... it has never done this before until I changed the lines and master cylinder.
04es1civic
Suspension & Brakes
Aug 20, 2011 12:04 AM
patrickstar
Suspension & Brakes
Apr 24, 2009 12:41 PM
pineapplemike
Nov 23, 2005 07:25 PM
Turbo Dan
Apr 7, 2005 01:21 AM
SiR HatchAlot
21
Nov 28, 2003 05:53 PM
