Is it hard to install a turbo
Old Jul 12, 2001 | 12:55 PM
95gsr's Avatar
Default Is it hard to install a turbo
is it hard? I AM A do it yourselfer can i do it
thanks
Old Jul 12, 2001 | 01:32 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Is it hard to install a turbo (95gsr)
If I can do it, with the help of people here on the board, then anyone can. Look at dustins pics to help you out.
art
Old Jul 12, 2001 | 02:33 PM
Smashback's Avatar
I'll let you know next week
It can't possibly be worse than installing a motor though!
Old Jul 12, 2001 | 03:30 PM
Rob03Pro5's Avatar
Default Re: Is it hard to install a turbo (mplex2000)
Fisrt hand experience with SenekaGSR's car.. yes it is very doable. Importparts.com also has instructions online now.. but no diagrams . It still is a fairly easy project tho.. just be prepared to buy certain tools.. cuz you'll find along the way that the tools you have just wont cut it. Oh, and common sense plays a GREAT deal on all this! So I hope you have plenty of it! ( I'm sure you do)
Old Jul 12, 2001 | 03:46 PM
GSRwBOOST's Avatar
Default Re: Is it hard to install a turbo (Rob92SC)
it's a good learning experience..not pleaseurable while doing it when you get frustrated.. but it was def. worth doing ...
Old Jul 12, 2001 | 04:24 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
D.I.Y! just follow your instructions and if you know the basic parts of the system and where they go it should be very easy. take your time and don't rush the install. after you'll be glad you did it yourself...people may then flock to you for paid installs .
Old Jul 12, 2001 | 05:56 PM
Smashback's Avatar
10mm, 12mm, and a screwdriver. You should be set. Those tools will let you do anything from installing a stereo to bleeding the brakes on a Honda
Old Jul 12, 2001 | 09:54 PM
GSRwBOOST's Avatar
a little more tools than that.. but LOL.. just have a nice complete set of tools available. i went out and got a set from sears.. after all i'm gonna have to do work on it in the future anyway...
Old Jul 13, 2001 | 06:37 AM
nerdish's Avatar
Default Re: Is it hard to install a turbo (GSRwBOOST)
What kind of maintence does a turbo involve?
I think I've heard changing the oil every 2000 miles.. but, anything else? I'm guessing regular compression checks, but.. what else?
Old Jul 13, 2001 | 06:40 AM
b18bturbo's Avatar
Default Re: Is it hard to install a turbo (nerdish)
just regualr maitaince will be fine 3000 mile oil changes always keep a filter or some sort of screen on the compressor side. Make sure its always clean and well oiled. Always check oil lines for leaks etc otherwise nothing major happens. Usually a turbo with a good amount of bosot will need rebuild around 60k-80k miles.
Old Jul 13, 2001 | 10:22 PM
pissedoffsol's Avatar
25 Year Member
can you link me? i tried to find it, but no luck...
Old Jul 13, 2001 | 10:43 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Is it hard to install a turbo (delvtecsol)
If you try to do a direct link it will take you to the front page..so what you need to do is go the the main page then click on customer service. From there you will click on the Drag install page.
art
Old Jul 14, 2001 | 06:40 AM
DirtyLude's Avatar
Default Re: Is it hard to install a turbo (Arturbo)
Not the same car, but it gives you a general idea of the install by someone who's obviously never done it before:
http://www.hondaprelude.to/articles/inst_turbo.html
4LugR
Sep 23, 2005 11:55 AM
blackcivic44
Dec 16, 2004 12:42 PM
k2civic
Dec 9, 2003 05:16 PM
turbocoupe
Oct 22, 2001 09:47 PM
MiLLerGSR
Oct 9, 2001 08:56 PM
