What kind of fuel pump should i do?!?!
Old Jul 13, 2001 | 09:17 AM
GSRacer's Avatar
New User
Default What kind of fuel pump should i do?!?!
i'm planning on running 100 hp direct port system. what kind of pump should i get??! it's for a 2000 gsr. what other accesories do i need to run that much safely? i know that i need to retard my timing. what size fuel jets should i run? what else? any ideas? thanks
Old Jul 13, 2001 | 10:27 AM
GSRacer's Avatar
New User
Default Re: What kind of fuel pump should i do?!?! (GSRacer)
i guess no one had any idea about nitrous!?!?
Old Jul 13, 2001 | 11:12 AM
Ben Huynh's Avatar
NOS Fuel Pump.
Old Jul 13, 2001 | 11:35 AM
Liltrix's Avatar
Default Re: What kind of fuel pump should i do?!?! (ben@importparts.com)
Is this motor stock? If so I dont know how safe that is! 100 Shot on a stock motor is not a good idea. On ythe other hand a turbo kit might cost just the same and U dont have to refill anything, its also much safer, and makes more power in the long run.
Old Jul 13, 2001 | 11:59 AM
GSRwBOOST's Avatar
Default Re: What kind of fuel pump should i do?!?! (Liltrix)
well ehre's a small list of what you will need....
1. clutch
2. header
3. exhaust
4. larger injectors (no kit is perfect)
5. larger pump (NOS makes a nice big one)
6. common sense (it's very expensive and sold by the ounce)
7. LSD (unless you like one flat tire and one good one in the front)
8. better than stock tires
anymore i think of i'll let youknow....
best to go turbo!
Old Jul 13, 2001 | 11:03 PM
BoM's Avatar
BoM
Default Re: What kind of fuel pump should i do?!?! (GSRwBOOST)
maybe new injectors and maybe an ignition system, just in case u miss a gear ... if u can get the fuel there, u can run it.....i think u should have jets for 75....u can run that ez with the gsr
Old Jul 14, 2001 | 07:21 AM
GSRacer's Avatar
New User
Default Re: What kind of fuel pump should i do?!?! (bommiE)
ok, i have intake, header, cat-back exhaust, fpr and msd sci ignition. i had the zex kit set at 75hp before. i recently sold my zex. now i want to got with nos direct port. 100 hp jets are safe if done right. at least that's what i heard. i would love to go turbo... but it's going to cost me a pretty penny. i don't have $3000-4000 right now.
nicko360
Feb 7, 2007 09:43 PM
hondaeg8
Sep 19, 2004 03:19 PM
pocketricerocket
Feb 11, 2003 08:35 AM
ridnmyhonda
Jun 17, 2002 03:27 AM
