How do I connect a 4-wire Heated O@ to a P28?
Can someone tell me how to convert my one-wire O2 sensor on a PR3 to a 4-wire on a P28? Basically need the pinout on the P28...
Thanks!
Thanks!
The CX is a 1 wire O2 sensor that is a WHT wire that goes directly to D14 which is O2 sensor input.
To convert to a 4 wire O2 sensor. That WHT wire will be utilized and goes to the WHT wire on the 4 wire O2 sensor.
The others are as follows from the O2 sensor, wire color change (if any) and to the according pinout to OBD1 ECU:
From O2:
O2 ground: GRN to GRN/WHT to D22 (which is also for Intake Air Temp sensor (white sensor on the intake manifold)
O2 Power: BLK to YEL/BLK to junction connector that goes to A25 (or B1, whichever you prefer)
Heater Control: BLK to ORG/BLK to A6.
HTH man
From O2:
HTH man
DarkBuddha
Nov 3, 2005 03:13 PM
Dancing is Forbidden
Nov 18, 2003 08:51 PM
HXMan
Apr 26, 2002 08:13 AM
