would blow by
Old May 22, 2003 | 10:37 AM
Black DC2's Avatar
Default would blow by
hurt my horsepower # i know is a stupid ? but just want to know
Old May 22, 2003 | 10:44 AM
Crazydave's Avatar
Default Re: would blow by (Black DC2)
yes
Old May 22, 2003 | 11:22 AM
AllmotorJunkie's Avatar
Blow BY will hurt more than just HP. It will cause your engine to run severely inefficient.
Old May 22, 2003 | 11:27 AM
Nextelbuddy's Avatar
Default Re: would blow by (AllmotorJunkie)
what the hell is blow by???
Old May 22, 2003 | 11:45 AM
Black DC2's Avatar
Default Re: would blow by (nextelbuddy)
ok guys here is the problem i just build my motor but the is alot of with smoke coming out the valve cover breather i check the compresion and did a leakdown and it was good what would u do wait for it to break in or just take the whole motor apart and do it again we may think that it need it to be bore to .0020 over but i already had bout the piston for stock bore they said they would do the work for free again all i have to do is pay for the machined shop to get it hone and just pay for the new pistons
Old May 22, 2003 | 11:50 AM
1_bad_EF's Avatar
stock bore pistons in a used motor will smoke 9 out of 10 times
did you use new factory rings?
I always recommend bore and hone and oversize pistons
Old May 22, 2003 | 01:36 PM
Black DC2's Avatar
Default Re: would blow by (1_bad_EF)
no i used 9-8-1 je piston and rings
Old May 22, 2003 | 01:38 PM
dfoxengr's Avatar
u didnt run 20w 50 motor oil for 1000 miles did you..?
Old May 22, 2003 | 01:42 PM
Black DC2's Avatar
Default Re: would blow by (hybridvteceg)
i only have 100 miles on the motor and i used regular 10w 30 motor oil
Old May 22, 2003 | 01:45 PM
dfoxengr's Avatar
u need to use 20/50 to seat the rings properly then flush it after 1g miles
Old May 22, 2003 | 02:12 PM
IEATLINT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">what the hell is blow by???</TD></TR></TABLE>
i think its caused by fried rings or something but what exactly is it and what causes it???
Old May 22, 2003 | 02:37 PM
Black DC2's Avatar
Default Re: would blow by (IEATLINT)
so what u guys r saying is all the f******** white smoke coming out my breather is because of my rings not being seated yet so like after 1000 miles the white smoke should go away then
Old May 22, 2003 | 04:26 PM
Turbo Powa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmotorJunkie &raquo;</TD></TR><TR><TD CLASS="quote">Blow BY will hurt more than just HP. It will cause your engine to run severely inefficient.</TD></TR></TABLE>
And eventually **** something up.
Old May 22, 2003 | 04:27 PM
dfoxengr's Avatar
should and using the proper oil
Old May 23, 2003 | 05:26 AM
JimBlake's Avatar
It's when your piston rings don't seal real good. They let the high-pressure combustion gases past them, & into the cranckase.
Old May 23, 2003 | 08:20 AM
jdmillusion's Avatar
yes. it can. when you feel gas in your stomach, and you're ready to dispose, how would you feel? lols. it's waste gas. that's when pcv's come in action.
edit:
so it is recommended to use a higher viscosity motor oil, when braking in a newly rebuilt motor? how high of a grade would you go up to? how about used, off the crate motors? just curious. much appreciated.
Old May 23, 2003 | 09:37 AM
Mr Hammond's Avatar
a/k/a Jomo
So you are using stock 9.8:1 81.00mm JE's? Who is your machine shop? Where the cylinder walls honed at all?
Old May 23, 2003 | 11:55 AM
Blow By can be caued by many factors. Especially incorrect installation of the pistons & rings. It happened to me...!
Old May 23, 2003 | 06:07 PM
Black DC2's Avatar
Default Re: would blow by (Mr Milano)
yes i forgot there name but it was honed (cleaned up)
Old May 23, 2003 | 08:21 PM
Westrock2000's Avatar
Now with blow by will you experience accellerated oil consumtion. I installed my own pistons and rings (first time too) and I always get afraid they didn't seal right, but I don't seem to be losing oil very much at all.
Old May 23, 2003 | 09:02 PM
Black DC2's Avatar
Default Re: would blow by (Westrock2000)
i'm not losing any oil either i'm just getting alot alot of white smoke out my valve cover hole that connects to the intake
oxSLEEPERxo
Jun 25, 2007 08:35 AM
premo_si
Mar 5, 2006 08:31 AM
B19CivicHB
Jun 19, 2003 04:15 PM
shermanyang
Oct 18, 2002 04:29 PM
