Questions for anyone running multiple coils or coil on plug
What setup are you running? which coils, wires if any, and are you using an MSD box with it? Just curious as to what my options are.
thanks,
Jared
thanks,
Jared
I am eventually gonna have this setup. Autronic cdi and mercury marine coils with magnecore wires.
If the autronic is out of your range i would go with the msd dis 4 ho.
yeah I wish I could run the motec cdi box I just dont have that much to run there stuff. the only change Ive made is the box and coils.-pdang
also, you're gonna need a engine management system with 2 outputs for waste spark configuration or 4 outputs for a coil on each plug.
also, from what people tell me, you're gonna need an autronic 500R or motec cdi 8 to fire off the mercury marine coils. the msd stuff isnt gonna cut it.
mercury marine is a company that manufactures boat engines.
You can use a speed pro with a crank and cam sensor in the distributor along with the E-Dist. Although don't plan on getting any help from them on the install.
GEN2TEG
Mar 29, 2003 08:34 PM
