Cam Seals ??
Old May 22, 2003 | 12:34 AM
Twigster311's Avatar
Default Cam Seals ??
I picked up a set of OEM cam seals from Inline4. Little hard rubber rings, basically.
But how come i see aftermarket, triple-ring cam seals? Golden Eagle makes them, AEBS makes them, and they look huge compared to the little oem pieces. What is the function of these, and is it just me or do they look 10x the size of the OEM seal ?
thanks
Old May 22, 2003 | 12:51 AM
_BEN_'s Avatar
Default Re: Cam Seals ?? (Twigster311)
They just look big in the pics.
Those big triple/double o-ring cam seals go on the right hand side of the exhaust cam. A common seal that likes to leak and make your engine filthy.
The doughnuts go on the left hand side of the cams next to the cam gears.
If you dont want to blow 20+bucks on a machined seal from str,aebs,ge, or some other company pick up a stock seal for a integra type r its plastic and has an o-ring verse the b16 wich is a big rubber grommet. I dunno how much they cost in the u.s. but they are 800y here wich is about 6 bucks.
Old May 22, 2003 | 12:59 AM
Default Re: Cam Seals ?? (nosepkr)
awesome, good to know.
I will probably go with the ITR, OEM reliability, unless there are any other reccomendations. Thanks!
Old May 22, 2003 | 04:52 AM
4DeepCivic's Avatar
Don't forget Hondabond. That helps to seal.
Old May 22, 2003 | 06:36 AM
WAFFLES's Avatar
Default Re: Cam Seals ?? (4DeepCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DeepCivic &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget Hondabond. That helps to seal.</TD></TR></TABLE>
Do NOT install the cam seals without the Hondabond.
Old May 22, 2003 | 06:43 AM
TEGgirl's Avatar
Great info guys! Thanks! I just ordered some STR cam seals but I thought they were just for looks. I guess I should get some Hondabond for my husband.
SLOENUF
Mar 12, 2011 06:06 AM
HyperFlow
Oct 9, 2010 07:59 PM
Walterronny
Apr 16, 2006 05:16 PM
MattyP
Dec 31, 2004 09:41 AM
MattyP
Oct 14, 2004 03:59 PM
