SOHC Turbo>> LS rods & Stock pistons VS B16A rods & toyota pistons
Old May 21, 2003 | 11:32 PM
eddie1681's Avatar
New User
Default SOHC Turbo>> LS rods & Stock pistons VS B16A rods & toyota pistons
Is anyone running the toyota combo yet in the US? How about the LS combo?
I can't decide which to go with.
I plan to run 10psi daily and 12psi when I am bored
Thanks
Old May 21, 2003 | 11:43 PM
turbopanda's Avatar
Default Re: SOHC Turbo>> LS rods & Stock pistons VS B16A rods & toyota pistons (b20z)
I would never trust my stock D-series pistons under a boosted environment!
Old May 22, 2003 | 12:08 AM
T-sohctec's Avatar
Default Re: SOHC Turbo>> LS rods & Stock pistons VS B16A rods & toyota pistons (turbopanda)
I would'nt want to go through all the trouble of building a motor just so I could put in cast pistons, especially if I knew it was meant for boost.
I got nathans b16 rod/supra piston combo.
I just finished putting the motor together about a month ago. I've got 600 miles on the motor & the setup works very nice. I'm @ 5.5 PSI right now hopefully I can get to a dyno this weekend & see what they can really hold (15 PSI?)
Old May 31, 2003 | 06:18 PM
dubniK's Avatar
I'm thinking about getting Nathan's setup too. I'm curious to how much boost everything can take safely..
Old May 31, 2003 | 08:26 PM
Pengo's Avatar
Default Re: SOHC Turbo>> LS rods & Stock pistons VS B16A rods & toyota pistons (dubniK)
with the LS/b16 combo the block must be notched correct? how much needs to be notched, and more importantly, about how much should a shop be charging to do it?
skoodles2k6
Sep 18, 2007 09:27 PM
whitehatchguy
Apr 18, 2007 06:49 AM
VTgringo
Aug 1, 2003 10:04 PM
Goldfingiz
Nov 24, 2002 04:42 PM
98civicEX
Jul 29, 2002 07:09 AM
